would i gain more power at the track with a summit exhaust cutout?
Old Jan 24, 2001 | 02:49 PM
305tbilo3's Avatar
Old Jan 24, 2001 | 03:07 PM
ONEFINE8T9's Avatar
if u have a full exahaust the increase would be so minimal it wouldnt even be worth it. Im tellin u go with a higher stall converter. That would be the best bang for the buck.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Jan 24, 2001 | 11:53 PM
Basett Racing's Avatar
On my 89 RS, I went to the track one weekend and ran in the 15.10's all night. The very next week I put on a cut-out and went 14.91. The weather conditions were actually a LITTLE better the first week also. I only have 2.5" exhaust with a Dynomax Super Turbo, which is not the best flowing exhaust system, so ONEFINE8T9 might be right, meaning if you have a good 3" exhaust system, you may not see that much gain,but it got me almost 2 tenths, so for me,it was well worth it( especially considering I already had the cut-out)
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
[This message has been edited by Basett Racing (edited January 24, 2001).]
Old Jan 25, 2001 | 04:17 PM
mostafa3k's Avatar
I'm also interested in putting on a cut-out. Bassett, is it best to put it on before the cat or after?
Or perhaps, i could get a high-flow cat and put it after?
Old Jan 25, 2001 | 04:50 PM
MrJ's Avatar
MrJ
just for the record people, Basset's times don't count. He's running an LB9 longblock, with the better cam and heads.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Jan 26, 2001 | 12:46 AM
MrJ, After doing some pretty extensive research, I have concluded that my 305 IS essentially a L03.The L03 heads are #14102187, but my heads are #10159553, which GM says is a swirl-port design head. The parts guy at the GM dealer where the engine was changed looked up the records on when the engine was ordered, and repaced 2 years ago and it was ordered to be a L03 replacement. He says the heads (#10159553) are probably a replacement part #, but he could not confirm that, he did however, find some information saying they were a swirl-port head w/ 1.84int, 1.50exh, and 58cc chambers. So with this in mind, I put a dial indicator on the rockers and confirmed that the cam was the peanut cam. But it IS NOT a Lb9. By all practical purposes it is, or at least should be the equivelent to a L03. Swirl-port heads and the peanut cam, both of which I have, are what makes the L03 different than a LB9. I mean, I don't think my car is really much faster than other similarly modded L03's anyway, because I see people saying they have to "roll-out and nail it" , or "feather the throttle until it hooks up" which means they are on street tires and spinning, I'm not, I'm on ET Streets with a lot more than recomended air pressure with almost zero wheelspin. I also run no air filter, higher timing with about a 70-30 mix of pump gas and 110 octane at the track and I put about 50# of pressure in my front tires and like I said in my previous post, I run it with uncapped exhaust. Plus I know how to drag race, I've been doing it a long time - I mean I'm not bragging, but a lot of my friends cars' best times, especially 5 speed cars, have been with me at the wheel. All these little things help, and some of these are things the average street racer at the dragstrip just dosen't do or doesn't KNOW to do. I'd like to hear some other guys with L03's doing some of these things, I think you'd see a noticable improvement.
Mostafa3k,
I don't run a cat, but I'd say for sure to run it before the cat. I run my right off the y-pipe where it bends,right before where the front of the cat used to mount. It probably restricts the exhaust a little bit, when I have the block-off plate on, due to it being mounted in the bend, but it ran faster at the track with it open, and I could tell no loss in performance on the street (capped)when I welded it on, so I really think it is a good mod.
Trans: Turbo 350 w/ 4000 stall - Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Bassett Racing
[This message has been edited by Basett Racing (edited January 26, 2001).]
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
midias
Aug 22, 2015 01:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
