L98 heads bolt up to L05?
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Are iron and aluminum L98 heads direct bolt ons to L05s with no fitting issues?
How much more power would "113" aluminum heads add to an otherwise mostly stock L05?
Car: 1983 G20 Chevy
Transmission: 4L60
You would probably lose HP/TQ by swapping either of them on. That is without prom tuning.
Your L05 cam with 64 cc chambers stock, the corvette aluminum heads have 58cc chambers. Your L05 came from GM with flattop pistons. The L98 Corvette engines I have pulled apart had nearly 12cc dished pistons. That means that you will be up around 10.3-10.5:1 compression. That will drive you into ping city.
I am at 9.85:1 with cast iron heads and a ZZ4 camshaft and can barely run 93 octane, with a conservative timing map.
https://www.thirdgen.org/forums/tbi/...+heads+350+tbi
https://www.thirdgen.org/forums/tbi/...0-caprice.html
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
IMO and in a thift sense, using 1.6 stamped rockers, keeping your L98 cam, adding duals and CAI is where you should start.... followed by DIY ECM tuning. That should yield 240+ fwhp. If you ported the heads you have and did nothing other than those mods, you'd gain another 30. That would be a combo quicker than a stock 3.08 LT1 Impala SS. HTH.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Also keep in mind the L98 aluminum heads are missing one bolt-hole for the serpentine accessory brackets that needs to be drilled and tapped. Also, they dont have EGR passages, and there isnt a TBI intake I know of that lets you add an external EGR like the TPI does.
Car: 1983 G20 Chevy
Transmission: 4L60
Wow, that's news to me. Where did you hear that? Why do my 1987-1991 L98 Corvette heads have the middle four intake bolt holes at the older angle, then?
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 25, 2015 12:54 AM
