Running without egr?
Old Jan 22, 2001 | 08:21 PM
steve8586iroc's Avatar
Who has removed it and what problems/benifits have you had?
I'll be using a 454tb with a jr victor or performer rpm air gap on a 96 350vortec engine. Will I need to have a chip burned to run without the egr and not have problems with preigition?
Also what cam would you suggest with the stock heads?
I need some good advice on this one.
Thanks,Steve
Old Jan 22, 2001 | 10:18 PM
NJ SPEEDER's Avatar
i have never had a problem with mine out, i just used a check valve that i plugged off the other outlets on so the computer thinks it is doing something. that way it won't pitch a code. if you get a custom chip burned just have them turn the egr off and you can just get rid of the whole thing.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
Old Jan 23, 2001 | 04:53 PM
NJ, have you noticed the ecm pulling out any timing since you disconnected it? Did you have to compensate by retarding the timing any? I would hate to hurt my new engine before I have a chance to get it dialed in.
Thanks, Steve
Old Jan 27, 2001 | 01:20 PM
89RS355's Avatar
I did what NJ said without any negative effects a while ago. I am currently experienceing some running problems, but not realted to the egr bypass.Although I am not one to talk as I still have a sock chip, but I would reccomend a good chip program to get the most out of your setup, Steve.
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
mdtoren
Aug 16, 2015 05:45 PM
camaroken83
Aug 10, 2015 11:35 AM
drathaar907
Aug 6, 2015 04:20 PM
