How can you tell if timing needs to be adjusted?
Old Jan 21, 2001 | 10:52 PM
Josh 91RS's Avatar
Im doing a tune up on my car. Well little by little at least...bought it used so im trying to go through everything that needs to be gone through. Im wondering if you have to adjust your timing at every tune up or if not how you can tell when it needs adjustment. I know this might be a remedial question...but hey, we all got to start somewhere.
Old Jan 22, 2001 | 12:36 AM
Andy89RS's Avatar
Get a timing light and check it. That's really the only way to tell. Stock specs are for 0* advance, but you get better high end power with a bit more. I have the best luck with 4*, but experimentation is the way to go.
Old Jan 27, 2001 | 01:36 PM
89RS355's Avatar
Yup. The only way is to check it with a timing light. If you don't have on, you can get them pretty cheap. Don't waste money on the shiny, high dollar ones. If your still at stock, try advancing it just a hair like Andy said and you should notice a small amount of performance gain.
You should Check the timing at every tune up. Also, it helps to clean off the balance and use some white out or white paint on the timing marks to make it easier to read. Make very small adjustments with the Distributor, and always double check timing after you re-tighten the distributor hold down to make sure you didn't move it on accident.
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
