Vortec Heads for a L03
Old Mar 7, 2001 | 04:23 PM
CleanRS's Avatar
Car: 1990 LX hatch
Engine: 5.0
Transmission: t-5
Axle/Gears: stock
Will Chevy's Vortec heads bolt up to a 305? I ahve always heard that 350 heads will screw up a 305.
Old Mar 7, 2001 | 04:40 PM
White92RS's Avatar
They won't screw it up, but Vortecheads for a 305 have a 64cc chamber I believe. And 305 heads have 58cc chambers. So you will have to have them milled. Also as far as I know you cannot go bigger that 2.02 1.94 on the valves.
Old Mar 7, 2001 | 06:29 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you will need a vortec type intake
Old Mar 8, 2001 | 08:13 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah you will definitely need to get them shaved down because with that chamber, you will get WAY too low compression ratio. if you take of some material, you will be all set. i odnt remember exactly what the spec was though, but you should be able to find it somewhere.
other than that they will work great.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Mar 8, 2001 | 08:15 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i just looked through some old magazines...
mill the heads 0.045", and use a 0.015" head gasket to get just over 10.0:1 compression.
maybe a little high for an L03, but you get the idea.
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
