new cam,more power?
Old Mar 14, 2001 | 10:31 AM
88firebirdTBI's Avatar
new cam,more power?
I am looking into getting a new cam for my LO3 305/TBI. i was wondering when i do the cam, what other parts am i gonna have to replace? Rocker arms? lifters? valves? what?
Old Mar 15, 2001 | 09:43 PM
jase's Avatar
u will have to puy new lifters in for sure.
Old Mar 15, 2001 | 11:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope, as long as your lifters, pushrods, and rocker arms are in good shape, you can reuse them with a new roller cam with no problems.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 17, 2001 | 11:12 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
a new roller cam of nearly the same specs right? surelly you cant put a .600 lift cam in with stock springs! you will float the valves for sure, if your pistons dont hit the first...
then again ive never put a new cam in a stock 305, what do i know...
Old Mar 18, 2001 | 01:38 AM
Kevin91Z's Avatar
Right, I was assuming putting in a cam that will work with the stock stuff. If you put in a big cam, you'll need to replace the springs, as well as check piston to valve clearance and coil bind on the springs.
Old Mar 18, 2001 | 09:14 AM
jase's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
Right, I was assuming putting in a cam that will work with the stock stuff. If you put in a big cam, you'll need to replace the springs, as well as check piston to valve clearance and coil bind on the springs.</font>
I would not use the stock stuff,but then again I would like mine right.Just an opinion though.Different srokes,Different folks.
gta90
Sep 15, 2015 04:00 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
