Installing My Open element
Old Mar 22, 2001 | 08:22 PM
MurphsIroc's Avatar
Alright, I got the stock air cleaner almost off, Now I see these wires hanging off the bottom. And i dont know what to do with them. And what do I do with the PCV valve that was on the side??, do I let it just dangle? I am a little confused right now, a little help will do the trick. thanks alot
Old Mar 22, 2001 | 08:36 PM
Neo's Avatar
Neo
Check this out http://snflupigus.tripod.com/tech/op...tep1/step1.htm
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
My Baby
Old Mar 22, 2001 | 08:38 PM
Andy89RS's Avatar
The PCV valve that was on the passenger side valve cover should be replaced with a breather. The electrical wires lead to a sensor in the air cleaner assy that you'll need to install in your new one, or elsewhere close to the intake. The vacuum line that led to the Thermac on the snorkle can be removed, and the port capped. If you don't have a cap, a screw or even a golf tee in the hose will plug it nicely.
Old Mar 22, 2001 | 10:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I could not get the breather to re-attach so I went to the auto store and bought an actual filter replacement and rubberbanded it around the end of that metal pipe. I wanted to fit an aftermarket breather on there but all the ones that I bought did not fit with the space allowed so I had to rig it up.
Old Mar 22, 2001 | 10:42 PM
Neo's Avatar
Neo
<font face="Verdana, Arial" size="2">Originally posted by ShiftyCapone:
I could not get the breather to re-attach so I went to the auto store and bought an actual filter replacement and rubberbanded it around the end of that metal pipe.</font>
What metal pipe? Your exhaust manifold? Is there a grommet that you can take out of the hole in your valve cover to make a breather fit in? I had to do this on mine.
Frozer!!!
Jan 19, 2024 04:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
