just got back from the track
Old Mar 24, 2001 | 12:17 AM
dreamsbird's Avatar
I just returned from the track and turned somewhat times.
r/t .641
60' 2.230
330 6.497
1/8 10.072
mph 68.39
1000 13.170
1/4 15.779
mph 86.50
any tips or tricks to shave .1 or .2 off my time would help
92 Firebird 305 tbi 700R4
14x3 open element
3/8" throttle body spacer
MSD blaster coil
Accel cap & wires
Bosch platnum +4
underdrive pulleys
Hypertech thermomaster chip
160 deg thermostat
gutted cat 3" pipe
full boar muffler(3" in dual 2 1/2" out)
3.42 open gears
Old Mar 24, 2001 | 12:30 AM
FastBroker's Avatar
Ask Pablo. He's got the 305 thing down...
Old Mar 24, 2001 | 01:23 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
That was lame
but to dreamsbirds question, you sound like you are on the right track. If you just want a little more, drop your front swaybar, air up the front tires to their max inflation pressure (usually like 45 psi or so) and where is your timing at? I never got to test with mine when it was stock but looking back it would seem like somewhere between 4 and 8 deg base timing is where youd wanna be
Old Mar 24, 2001 | 09:17 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
15.779
14x3 open element
MSD blaster coil
Accel cap & wires
Bosch platnum +4
underdrive pulleys
160 deg thermostat
gutted cat 3" pipe
3.42 open gears
Hmmmmm, nice set of headers and a cat-back would knock .4-.5 off ur 1/4 mile probably. And a TransGo Shift kit would probably knock off another .1-.2 But a full exaust system can get expensive. Around 600.00 after coating the headers. TranGo's are like 120.00
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 24, 2001 | 05:52 PM
dreamsbird's Avatar
I tried to advance the timming once but I got an extreme amount of pre-det ping. So I put it back to stock.
Old Mar 24, 2001 | 07:16 PM
NJ SPEEDER's Avatar
make sure the tune up on your ignition is good, hei dist. caps always get junky fast. also look at the tech articles and try to get every thing in the ultimate tbi stuff and the torque converter lock up. that should be worth a bit.
the big stuff would start with a posi rear and some good gears, 3.73's are the prolly the best.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 24, 2001 | 10:04 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
He has 3:42's Tim.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 25, 2001 | 12:40 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hmm, advanced it past 0 and you got alot of ping? that sounds weird. With the timing at 0 and with whats on the chip, L03s only have about 28 degrees total timing which is very conservative. Did you adjust the timing correctly, that is with the est disconnected?
also, headers arent that expensive, you can get a set of flowtechs for 80 dollars and their y pipe is 100, out of the box its more than adequate
Old Mar 25, 2001 | 07:45 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
One quality part is better than 100 cheap parts. So don't go the cheap way friend. You will regret it.
Old Mar 25, 2001 | 08:40 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
As if you would know since youve modded your car so much and have experience with a variety of headers and their pros and cons.
Ive seen a bunch of thirdgens with headers, and installed a few, cheap, uncoated. They all get the job done adequately and if you prep them well the rust is extremely minimal (far less than the factory manifolds anyway) even if you dont prep them well and they just flat out rust, ive never seen them rust to where holes formed or anything negative happened because of it other than not looking great. Ive been going strong for 2 years with edelbrock headers that were used for a year before I bought them.. all that time they were uncoated. They are fine, and the money i saved in not coating them went to other mods. Ive also seen flowtechs and hookers (the headers) in action. Spending anything more on a basically stock thirdgen that isnt worth much to begin with is just pissing in the wind.
Sorry for going off on the header tangent but i thought there was some misinformation floating around out there
Old Mar 25, 2001 | 12:08 PM
ONEFINE8T9's Avatar
with a cat back i doubt ud see a .5 difference from headers. Maybe like .2 but no way .5, thats like a 50 hp increase and i know for a fact that u dont get 50 hp from headers. Maybe like 20 or so. I do however agree about the shift kit. Thats good for .1/.2 in the quarter. IF u dont wanna spend 120 for a shift kit (which is pretty expensive) u can get a B&M shift kit through summit for 25$ and works just as well. A buddy of mine had that and a 4.10 posi rear end installed in his LG4 camaro and he chirps them into 3rd if he hits it right...he also has the edelbrock eliteseries and K&N filter to (that bastard )
Old Mar 25, 2001 | 02:24 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
<font face="Verdana, Arial" size="2">with a cat back i doubt ud see a .5 difference from headers. Maybe like .2 but no way .5,</font>
I was talking about headers and a cat-back.
And Pablo, whatever u say man. Look how far ur cheap a$$ parts have gotten u. TRAP SPEED TRAP SPEED! LoL
Trust me Dreambird, I have bought cheap parts before and they never last. Your better off buying quality parts then some parts u find at a junk yard. Espically when it comes to internal parts that would wear with age.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 25, 2001 | 06:22 PM
NJ SPEEDER's Avatar
hey 91birdbrain305,
i saw that he has 3.42's and 3.73's would be worth more. and since when is the tune up you mention in your first post a mod? plug wires only make people faster if their old tune up is totally wrecked.
why are you worrying about pablo's combo too. yer car seems a bit slow and lacking in timeslips for anyone to think you have the slightest clue what you are talking about.
up til now i have been going about this with a very laid back attitude toward your mindless posts. if you keep just ripping on everybody and trying to misinform,actions will be taken.
lata
tim
Old Mar 25, 2001 | 06:26 PM
ONEFINE8T9's Avatar
oo ok, my bad eric, i should have read a little better.
dreambird NEVER buy junkyard parts for internal engine parts. Thats deffinetly something u dont wanna do and pablos times will continue to be limited until he changes those damn junkyard heads. No offence pablo
Old Mar 25, 2001 | 06:39 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey sorry Tim. Guess I should keep that sh*t off the boards. My bad Tim.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i think when talking about performance increases people should assume not to get a standard hp# increase, but a closer assumption would be a near standard % increase.
Old Mar 26, 2001 | 05:39 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
snf you are probably right
and whats this talk about not using used parts? you two arent using used parts and look how slow your cars are! nuff said!
btw my heads werent from a junkyard but they were used. Nothing wrong with them in terms of a defect. Even if they were brand new out of the box from gm with the same porting job they would give me the exact same timeslip.
sorry dreamsbird, back to your post
also look into relocating the battery, I believe basset racing saw a difference in ETs after this mod (im perpetually planning to do it just never have myself)
Old Mar 26, 2001 | 07:11 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
<font face="Verdana, Arial" size="2">you two arent using used parts and look how slow your cars are! nuff said!</font>
LoL, yeah ok man. Sorry we haven't done heads/cam/intake like u have and run an amazing 14.88 in the 1/4 mile.
Anyways, yeah I think I heard someone say that the battery moving idea was a pretty good one, but something that would be used as like a touch up mod. Touch up mod as in like an alliunium driveshaft or something like that. Stuff that helps but nothing enoroums comes from it.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 26, 2001 | 07:43 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
14.88 is better than your... oh wait.. you dont even have a timeslip! get lost kid
Old Mar 26, 2001 | 09:30 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
LoL, ok dude. I like how u talk sh*t now that u have a timeslip but all that time from before when u had nothing u talked like ur car was the sh*t still.
Old Mar 26, 2001 | 10:25 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
dreamsbird,
you might want to consider picking up a performer intake for 150 or so, that should let your car breath better and would most likely net you a little more than .1-.2.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 26, 2001 | 11:53 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey Tim. What would be the point of installing 3:73's when he already has 3:42's? Seems like a waste of money if u ask me.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 26, 2001 | 01:51 PM
ONEFINE8T9's Avatar
<font face="Verdana, Arial" size="2">and whats this talk about not using used parts? you two arent using used parts and look how slow your cars are! nuff said!</font>
pablo i know u werent trying to take a shot at me are u? Dont get mad becouse u dumped ur life savings on a motor that runs high 14s. Ya thats something to brag about man if we all only used junkyard parts we would be as fast as pablo
BTW my car probably runs within .3 of your car and i havent touched a thing.
<font face="Verdana, Arial" size="2">LoL, ok dude. I like how u talk sh*t now that u have a timeslip but all that time from before when u had nothing u talked like ur car was the sh*t still. </font>
eric dont let this clown bother u. Hes just mad becouse he isnt quite the TBI god some may have made him out to be. a built up, bored out 5 spd TBI that runs a high 14 is pathetic. On top of that his car is all ghetto rigged so its not like hed ever see more than 4 grand for it n e way. So all the **** talkin he does and he doesnt have a fast car nor does he have an origional one. damn ricans......
ok snflupigus, im sorry for this off the topic post ut he took a shot at me first. This will be the last from me about pablow.
dreambird u are looking for a quick few tenths. A shift kit is probably the cheapest way for a few thenths. If u wanna spend a few $$ on a nice mod than i would recomend gears over n e thing. Gears is one of the biggest limits on our cars from stock. I know of a guy in an 89 RS on this board that ran a 14.9 with 3.42 gears,posi and an exahaust cut out. Of course with the classic open element. So as for mods do **** kit, and start saving for rear end gears. Dont relocate the battery or remove the sway bar or n e thing like that. ITs really not worth the time to do that and things like that are so ghetto...
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
