Compression Ratio w/GM Vortec Heads
Old Mar 31, 2001 | 04:28 PM
killerRF's Avatar
Hello. I was going to put them Vortec heads on my '92 chev 350 1/2 ton. i know that the bottom end of the engine is all stock and stock has dished pistons but i dont know how much they are dished. But the stock compression of the engine is 8.5:1. Now i was going to put a gm comp head gasket that is .028" compressed. What would my compression ratio be with the new heads, this gasket, and stock gm dished pistons?
Old Mar 31, 2001 | 04:36 PM
Brent's Avatar
Your stock heads have the same chamber volume as the vortec heads (64cc). If you use the stock type gasket, compression will remain the same. I believe the stock gasket is a steel shim (.015-.019 thick). Using a thicker gasket will lower your compression ratio.
Old Mar 31, 2001 | 04:43 PM
killerRF's Avatar
Hello. Are you sure that they are 64 cc already? I thought that they were 72 or 76 cc chambers. When we took off my friends heads off of his '91 GMC 350 sierra ST to put on Edelbrock performer heads... the chambers were much bigger than 64cc. Im sure of this. Maybe in '92 they were different? I dont know.
Old Mar 31, 2001 | 06:10 PM
Brent's Avatar
Perhaps I'm mistaken. Anyhow, if you go from 76 to 64cc heads and keep everything else the same, you will gain 1 point of compression. 9.5:1 in your case *may* be too much with the stock cam; resulting in detonation.
Check out: http://prestage.com/carmath/
Old Mar 31, 2001 | 10:13 PM
Keith5's Avatar
Car: C1500
Just use higher octane and a lower thermostat to be safe from detonation.
Old Apr 2, 2001 | 08:36 PM
FastBroker's Avatar
You should be ok with 92-93 octane and 9.5CR.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
earlpote
Aug 28, 2015 10:42 AM
