SLP posi on this weeks special, will help tame our mighty lo3's
Check out this weeks special. I've got mine ordered. http://www.slponline.com/view_produc...TNUMBER=64501T
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Can that be used on the stock rearend with the 2.73's? I want limit slip but can't afford the 3.42's to go with it. I am sick of one wheel drive. I don't really mind the 2.73's for now but i would like power to go to both wheels when it is needed.
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
1990 RS 305 TBI T-5
Custom Exhaust
ya i would like to know if they are available for 2 series gears. My friend just had 4.10s put in his camaro and he wanted to get a good posi unit. The problem is he got the gears for a 2 series carrier becouse his old gear was a 2.73. Will the SLP unti work with both 2 and 3 series gears??
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Damn, I need a new posi and gears bad, and I need them for a 2 series
1992 RS
305 TBI, Edelbrock Performer TBI, TPI heads, Open K&N filter, SLP 1 5/8" headers, !cat, custom 3" exhaust, Flowmaster 80 series, MSD 6-AL, MSD Blaster GM coil, Accel Cap and Rotor, Accell 8.8 MM wires, World Class T-5, B&M Ripper Shifter, Nitto 275/50/15 Drag Radials, Radial T/A's up front, LakeWood LCA's, Edelbrock panhard rod, Aluminum driveshaft, LakeWood Drag shocks, IROC rear springs, custom interior, etc.
1992 RS
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I suggest you give them a call. I ordered a 3-series and they implied that they carried both types
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I don't know any posi unit that works with both carrier sizes. You need to call and make sure u get a carrier 2 posi if you are going to keep them 2:73's. But if I was you, ordering the carrier 3 posi and then later on ordering the gears would save u money in labor and in an extra set of gears.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: '90 RS
Engine: 377 LSX
You ar eprobably right. i will just have to wait until the money flow increases.
1990 RS 305 TBI T-5
Custom Exhaust
1990 RS 305 TBI T-5
Custom Exhaust
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
the take off units ONLY accept gears 323 or higher.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
91 camaro RS
- 305 TBI
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont even bother keeping your 2.73 or 3.08 gears. If you're putting in a posi unit, get 3.23 or higher gears. Its VERY worth it. You can pick up a used set of 3.23 or 3.42 gears from a 4th gen car at their classifieds, like ls1.com or camaroz28.com. Dont forget you have to change the speedo gears in your trans to match your new rear end gears, so your speedometer reads correctly.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Engine: 3.8
Axle/Gears: Dana 60
<font face="Verdana, Arial" size="2">Dont forget you have to change the speedo gears in your trans to match your new rear end gears, so your speedometer reads correctly.</font>
And that might cost ya around 200 bucks....well it does where I am from, maybe different where everyone else is. And I agree about getting rid of these 2:73's. With a set of 3:42's or 3:73's u can pick up an extra .4-.5 in the 1/4 mile. But I don't recommend used gears...I don't recommend anything that wears with age to be bought used.....but u can take that risk if u want.------------------
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 92RS
Engine: 357
I just changed my speedometer gears last weekend to match my 3.42 gears.Took me about 2 hours and about $20 worth of parts.I used the tech article and had no problems.I had to take the hold down bracket off the VSS sleeve and turn it 180 deg. because the new gear was larger (the driven gear shaft is off center).It worked great. By the way, I got the SLP take off posi last fall and I'm very happy with it.
[This message has been edited by JokerRS (edited April 05, 2001).]
Engine: 3.8
Axle/Gears: Dana 60
Save urself 180 bucks then and do it Jokers way.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
ok so no posi equipped trans am or firebird came with a 2 series gear? i thought auto cars had like a 2.73??? So if thats true they should offer a 2 series take off unit.....only if thats true
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
