13.9 on L05 long block?
Old Feb 18, 2007 | 03:46 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just curious if I could easily go 13.9 on my L05 long block, and what I would need to get me there. I'm using TBI and I can tune.
Old Feb 18, 2007 | 09:10 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dewey ran that all motor in his LO3 (not sure the exact ET) and without a doubt Fast355 has a few motors that would run faster than that if put between the fenders of an f-bod. Dewey ran a best of 12.9 (correct me if I am wrong) with that same combo and a shot of nitrous. You can tune so hitting a 13.9 is far easier than you think. Do you want to keep the heads stock and untouched? You may have to do a little work to them to accomodate various cam possibilites.
Old Feb 19, 2007 | 05:42 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
You're going to need somewhere north of 275 hp to go that fast, unless you have some drag gears, a huge stall or slicks or something like that.
Stock LO5's are around 210-220 hp.
Old Feb 19, 2007 | 10:05 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
I ran 13.6 in my malibu wagon, at 4000lbs with me and a full tank (lots of stereo equipment). I had a woeful 60 ft of 2.2, and a low trap speed of 98mph, I've done more tuning since then, and shoud have the n2o system fixed, looking for 12's. So it's possible, f-bodies are lighter.
Old Feb 19, 2007 | 10:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
10:1 TBI 355 with 180cc Dart Iron Eagles (49cc chamber, 2.02 intake, 1.60" exhaust), Production LT4 cam, Edelbrock 3704 intake, 454 TBI unit, 68# injectors at 30 PSI = 325 RWHP. Ran 14.7 @ 96 with a 2.18 60' in a 4,500 lbs 1994 G10 Cargo Van with the stock converter in the 4L60E, 3.42 gears, and P255/70/R15 tires.
Old Feb 20, 2007 | 08:53 AM
Car: 91 RS
Engine: 350 TBI
You had me going there for a second, because your setup is similiar to mine and then I saw the 14.7 and I was about to slap you. Then I read the van part (which I always forget).
Old Feb 22, 2007 | 07:55 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Lo-tec did it by using a junkyard Caddy LO5 long block into his 3rdgen, and to it he added a cam (204/214 ?), exhaust and a carb (avoided ECM tuning). He ran 13.6. Do a search and you'll find his post(s). 13.6 is on-par with a stock 4thgen LT1 car, so the engine made 260+ fwhp to go that quickly. So if you can tune you can duplicate his efforts with a cam+exhaust... as confirmed many times over by Fast355's work.
Old Feb 24, 2007 | 04:53 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
stock lt1 cars dont run no 13.6 stock..they run 14.0 flat AT BEST. LS1's at best stock run 13.8. Well that's what i have seen in my couple years of going to the race track.
Old Feb 24, 2007 | 06:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I've personally driven a 1997 LT1 SS with an Auto to a 13.7 @ 95 at 800 ft. elevation.
Old Feb 25, 2007 | 06:33 AM
kdrolt's Avatar
Engine: LO3, LO5
Elevation above sea level has a lot to do with performance. Likewise for the track condition, tires, air temperature and driver skill. When they're all cooperative, a stock LT1 Fcar can run mid 13s.
Undercover89TBI, what is the track elevation in California?
morrow
Jan 13, 2024 12:29 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Gunsbee
Sep 7, 2015 07:10 PM
