This is hard to post :o
Old May 9, 2001 | 10:04 PM
speedlvr's Avatar
A while back, I thought I had increased the fuel pressure all the way by adjusting the meter screw to where the spring was fully extended. When I took the throttle body off last night, I figured that I had actually lowered it as far as it could be by that means. Now the spring is fully compressed and needless to say, I'm quite pleased with what that did. Maybe my big screwup will help to keep someone else from making the same mistake.
Old May 10, 2001 | 11:40 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i did the same thing when i first adjusted my fp.
tight spring = high pressure
loose spring = low pressure
i ran lean for a few months before realizing my mistake. i think i melted some plugs a bit, and cleaned out the cat
Old May 10, 2001 | 01:32 PM
speedlvr's Avatar
Yeah? Two of my plugs have been prone during the last few months to turning pitch black but the others are ok. It was the 1st and 3rd plugs. Could it be that it was so lean that the gas could not make it that far before going into the other cylinders?
Old May 10, 2001 | 10:16 PM
speedlvr's Avatar
btt
Azrael91966669
25
Jun 20, 2017 04:04 AM
Chuck84TA
Jul 15, 2016 09:05 PM
777Shock777
Oct 29, 2015 04:30 PM
db057
Sep 4, 2015 07:57 AM
