1.6 ratio too much
Old May 13, 2001 | 12:37 AM
firbird's Avatar
1.6 ratio too much
Is 1.6 ratio too much for a pretty much stock tbi engine? My brother had some and I was bored one day and decided to put them on and my engine runs really rough at idle and runs rich and much more smoke comes out of my exhaust and there is not tapping coming from it. When I give it gas and it goes over 1500 rpm my engine becomes smoother. Do I have to adjust timing? do I have to adjust the fuel pressure? Are they not good on my engine? Just need some help thanks.
Old May 13, 2001 | 01:19 AM
Tas's Avatar
Tas
lol they should be fine but I hope they are self aligning like stock
Old May 13, 2001 | 01:49 AM
firbird's Avatar
hummmmmm self aligning No, no there not I am pissed I asked people around me they said that the Chevy engines were not and that mine were not self aligning and they would fit and I kept telling that they would not fit instill they convinced me that they were. Sounds like its about to die at idle like a race cam. Oh yea can I use the old rocker arms if they are not in order? (Friend mixed it up when I was taking them off)
Old May 13, 2001 | 01:52 AM
firbird's Avatar
Feel pretty stupid but didnot pay for them origonally $210 so dont care now have somethng to do
Old May 13, 2001 | 02:34 AM
Tas's Avatar
Tas
if there are no plates to guide the side to side movement of the pushrods then the tip of the valve needs to be self alighning. it will have a little dibbit in the middle to ride the top of the valve stem.
Old May 13, 2001 | 12:15 PM
NJ SPEEDER's Avatar
did you advance the initail timing a little. you hafta compensate for what the motor is gonna think is a bigger cam, just put a little more timing in it and it should smooth out nicely.
if you don't have self aligners you will need guide plates, but i don't think standard ones will work. you may hafta look into that. the centerbolt heads align the pushrod a little different.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
InfernalVortex
Apr 20, 2021 11:31 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
