TBI in a 69 Chevelle. Suggestions?
I have a 69 Chevelle, that I have/am in the process of putting TBI in. I have the TB mounted, and the computer hooked up, but not mounted. I ran the return line into a gas can , and cranked it up. the car ran great, but I still have some "loose ends" LOL I need some info on running a return line. I know this is pretty straight foward, but where do I get 20 foot lengths of fuel line?
I also have started "unfangleing" this harness. I have been pulling the uneeded wires egr etc out and seperating them fron the needed stuff. Should I just hack these off? or pull the pin out of the harness?
How about my O2 sensor? I know I will have to drill a hole on the collector, but where do I get a bung to weld in? Any suggestions and or comments are totally welcome.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
You can get bulk fuel line from Summitracing.com or jegs.com you could even go with braided stainless for ease of install depending on your bank account.
Were it me, I wouldn't cut anything from the harness - at least until you've been running for six months with no problems - but that's me, I could be wrong.
I picked up aluminum bungs from my local speed shop for my rig - alternatively you can go to Ace hardware types to find couplers that will work as well.
Hope this helps,
Steve
Steve's Trans Am Temple
Hope this helps,
Steve
Steve, I went and checked out your dual TBI setup on your page, and I do not think resistors inline with your IAC's will work. They are stepper motors if I am not mistaken, and resistors would just diminish the signal to the IAC's. BTW cool *** car. I like!!
Any more suggestions guys?
Any more suggestions guys?------------------
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Check with your local muffler shop, here in Ca. we use them all the time. (The o2 bung)
As for the return line, I went to a pick-your-part and pulled one out of a Chevelle that had a fuel canister. It's 5/16 line(steel tubing) and reaches all the way from the engine bay to the rear crossmember by of the rear end. Then hook it up with a short piece of hose.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Glowsock
Sep 11, 2015 11:09 PM
