I need some help guys....
Old May 23, 2001 | 09:00 PM
91RSconv's Avatar
I just did the free tbi ridge removal trick and while re-installing the unit something went wrong. The fuel inlet is leaking somehow between the two nut bolt combos at the end of the fuel line going into the tbi. It's only when I start the car that fuel drips out.( when I turn the key to "on" it is fine) What should I do? Do I need to buy new parts? Bend the fuel line? Add locktight to the threads!!!!!!!!
91' red RS convert.
71,000 miles
89' IROC hood
red Z-28 16" rims
potenza re730's
MSD ignition
MSD coil
K&N fiter
350 ported polished heads
hypertech chip
flowmaster 40 series cat-back
Old May 23, 2001 | 09:13 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
there is a plastic washer inside the fuel line conection.Mine was clear and hard to see.It fell out and I allmost lost it .I'm guessing yours is damaged or it fell out while you were working on it.They are in the TBI gasket kit.Hope this helps.
Dave
Old May 23, 2001 | 09:18 PM
91RSconv's Avatar
Where can I get this kit and how much is it? I already replacedthe tan ring around the fuel inlet line so I am assuming the clear one you are talking about is inside the doulble threaded nut. Someone please clearify for me.
Old May 23, 2001 | 09:24 PM
NotDadsW41's Avatar
The complete gasket kit, which you probably have to get to get the washer, was about $35-$40 last time I bought one.
Stratocaster
Aug 15, 2006 06:56 PM
85T/A
Car Audio
Aug 14, 2006 06:07 PM
z28monster
Jul 17, 2006 01:44 AM
WI-Z-Guy
Nov 30, 2005 10:03 AM
parks911
South East Region
Nov 10, 2005 07:47 PM
