where does MAP vacuum line hook up?
Old May 23, 2001 | 11:56 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ok..i had a code 33, low vacuum at MAP and i had checked it out and it was good. It was connected under the map and it ran back behind the engine....i tugged and it was good....but i decided to check again....and when i actually followed it back with my hand i found that it was not plugged into anything!!! no vacuum is definitely LOW vacuum so where does it go? into the TBI unit? thanks a mil
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old May 24, 2001 | 01:19 AM
JPrevost's Avatar
Car: 91 Red Sled
The hose isn't hooked up to your MAP sensor which is on your firewall. That hose needs to be hookedup to that.
, Jon (350 TBI!)
91 Red My website
Old May 25, 2001 | 12:12 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
The vacuum line runs to the back of the TBI unit. If this line isn't plugged then you probably have an irregualr idle to. The vacuum port is on the back of the TBI unit, low and in the center. Hope this helps.
-Lars
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
