very strange SURGING problem.......Help
Old May 26, 2001 | 03:31 PM
idrag2's Avatar
Ok the car is a 89 formula LO3 engine. I am getting a surging problem going down the hi-way trying to hold a steady speed and also under light acceleration. The car idles fine. And under wide open throttle it does good. I've narrowed it down to a fuel problem because I can clam off my return line to boost the pressure and the problem is gone, but under wide open throttle it starts to fall on its face on the upper RPM scale. So what gives???? Can anyone help me?????
Thanks for everything,
I DRAG 2
Old May 27, 2001 | 01:37 AM
JPrevost's Avatar
Car: 91 Red Sled
What kind of RPM does it start to cut out? Have you replaced the fuel filter lately?
, Jon (350 TBI!)
91 Red My website
Old May 27, 2001 | 01:03 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I had the same surging problems for two weeks. I started looking around and two of my plug wires were burned. Sorry I don't know about your fuel theory.
late model 91 rs
fully loaded t-tops
red leather
paint- gm red and yellow blend (light red)
custom pink rims
305 tbi 14"x3" O.E,
computer chip, accel super stock plug wires
MTX sub and amp (very loud)
vic_v8@yahoo.com
Old May 27, 2001 | 07:06 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Check your TPS sensor.
Old May 27, 2001 | 09:34 PM
idrag2's Avatar
ok, I replaced the fuel filter and replace the MAP,TPS,EGR,IAC. Everything is working right as far as these go. Brand new ingition system...............any other ideas........thanks for the help
I drag 2
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
92camaro350cci
Oct 14, 2015 09:29 AM
BWilcox
Sep 20, 2015 12:19 PM
banksGTA
Sep 13, 2015 11:56 AM
