SENSOR, IAC, MAP, TPS QUESTION
Old May 26, 2001 | 08:29 PM
z28camaro396's Avatar
One day i was doing some work on my car and my friend took off the vacuum hose from the breather. He started the car up and ran it w/the hose plugged into the breather nut rod coming up from the tbi. Ever since my car has been real hard to start. I have to let it idle at about 1500 rpm b4 I can go anywhere in the mornings. Has this possibly messed with my sensors. Also my "CHECK ENGINE SOON" light comes on all the time since then. Any advice?
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), kenwood c.d. player.
Old May 27, 2001 | 01:35 AM
JPrevost's Avatar
Car: 91 Red Sled
Did you read the code from the ecm? Do that and it should tell you exactly what's wrong with it. If you don't know how to read codes then check out <a href="https://www.thirdgen.org/newdesign/faq/thirdgen.shtml#misc">this link</a>.
, Jon (350 TBI!)
91 Red My website
Old May 27, 2001 | 04:53 PM
Vader's Avatar
Actually, that Tech Article is a little misleading. First, the ALDL is not identified by numbers, but letters - and the order in the Tech Article is backward.
Second, the two pins mentioned first in the article should not be shorted on anything other than the '82-'83 cars.
There are other problems, but you get the idea. This link may be helpful:
GM Error Codes.pdf
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 27, 2001).]
Old May 28, 2001 | 12:06 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
vader, please email webmaster@thirdgen.org about your findings about the tech article. we need to have correct info here.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
