help me please no start
Old May 27, 2001 | 07:55 PM
Alberocks's Avatar
I have 1989 formula 305 tbi that won't start I am getting spark and air just no fuel I spent all day repalcing the fuel pump (per the dealership) with no help. Im getting oil pressure and have replaced the fuel pump relay about 6mos ago so what can it be?
Maybe the escm (eletric spark control)???
please help with any thing!!!! Thanks
Old May 27, 2001 | 08:22 PM
jase's Avatar
Is there any power to the fuel pump at all?If there isn't that relay or a fuse may be the problem.
Old May 27, 2001 | 08:26 PM
Alberocks's Avatar
I checked the fuse before starting the operation today. Is there an easy wat to see if there is power to the fuel pump?
Old May 27, 2001 | 08:46 PM
jase's Avatar
You are going to need a test light once you find the right wires.Can you even hear the pump with the key just in the on poistion?A wire could be touching and grounding it out if the fuel pump is not working or its no good as well.Is there any thing else that its not doing?
Old May 27, 2001 | 08:49 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Check the fuel filter. Just my 2¢
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old May 27, 2001 | 09:00 PM
Alberocks's Avatar
I have never hear the fuel pump with the key on dad hearing i guess! Any idea what wires to start with??? thank you for the help so far!
Old May 27, 2001 | 09:08 PM
RyanSS's Avatar
Sounds like we are having about the same problem. look at this
https://www.thirdgen.org/messgboard/...ML/009244.html
89 RS (supposed 350) TBI auto
Old May 27, 2001 | 09:25 PM
Alberocks's Avatar
The car will run with starting fluid sprayed in the tbi. But just for a second. Any other ideas out there I need to get this done soon.
Old May 27, 2001 | 09:44 PM
jase's Avatar
Sounds like you might have done something wrong in the installation.You have spark but no gas.The only thing I can think of is a wire could be grounding out.
Old May 27, 2001 | 10:09 PM
Macgyver's Avatar
Remove your Fuel pump relay.
Get some thick wire and jump the orange wire and the red? wire. (just jump the two thickest wires going to the fuel pump relay)
If the fuel pump doesn't work then, then you must have a short in the wiring.
The fuel pump is turned on by two things. The ECM "primes" it when you turn the key, and the Oil pressure sensor. The OPS acts like a relay, no oil pressure=no voltage to turn your fuel pump on.
Old May 28, 2001 | 03:58 PM
Alberocks's Avatar
I tried to jump the two wires on the fuel pump relay still nothing but now I notice there is no SES (service engine soon light) on when I put the key in the acc position. Fill me in on what I should do next. Any help is welcome.
Old May 30, 2001 | 11:08 PM
Macgyver's Avatar
Check the two ECM fuses, on is in the fuse block, the other looks like a small relay, it's near the battery in a Camaro.
Old May 31, 2001 | 08:09 AM
FastBroker's Avatar
Definate fuel pump circuit problem.
Old May 31, 2001 | 09:42 PM
Alberocks's Avatar
The car will now start with the fuel pump relay "jumped" but I went out and bought a new relay still no start. So am I wrong in thinking that I will have to go through the whole wiring harness to find my problem. Any place that I should start with frist?
Old May 31, 2001 | 10:03 PM
steve8586iroc's Avatar
It sounds like your not getting any power to the fp relay on the primary side ( the one that energizes the relay too make the circuit from the battery to the pump ). It could be the oil pressure switch or something else. Try grounding the wire that goes to the ops, if the switch is bad then it should run with the wire grounded. Just my .02 .
Steve
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
