nitrous kits
Old May 27, 2001 | 10:02 AM
91rscruiser's Avatar
nitrous kits
hey does anyone know of a nitrous kit that is made for 305 tbi motors?preferably from NOS,but anything else would be acceptable.and is there anything you need to do to the ECU when you install nitrous?thanks for the help!
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,th700r4,only mod for now is a flowmaster 80 series replacement muffler.
Old May 27, 2001 | 10:29 AM
JPrevost's Avatar
Car: 91 Red Sled
Retard timing, read about N2o in the tech articles. <a href="https://www.thirdgen.org/newdesign/tech/nitrous.shtml">1</a> <a href="https://www.thirdgen.org/newdesign/tech/ednitrous.shtml">2</a>.
Every N2o company makes a TB plate, think about all the TBI trucks and 454 SS etc. They're usually a little more expensive then a normal carb plate but it's all the same. The plate injectos N2o AND fuel so you'll have to tap into our fuel lines. Isn't too hard considering we don't have high pressure fuel lines like TPI guys.
, Jon (350 TBI!)
91 Red My website
Old May 27, 2001 | 10:37 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
the kit for the 305-350 TBI from Nitrous Oxide Systems in #5153 i got mine from summit for i believe like $53. the kit is not hard to install just set aside about a good day to do it and take your time to do it right. I am running a Hypertech thermo master chip with 0 degree base timing and i use Texaco 93 octane gas and i have no problem with the juice ever hitting detonation.
Old May 27, 2001 | 10:39 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
$535 sorry not 53
Old May 30, 2001 | 07:00 AM
92fire-audio's Avatar
Does nitrous cause much physical damage to the engine? I've heard that it does many times but it's all been "my friends cousins brother blew his engine using it"..
I mean, If you have an engine in decent shape, should it be able to handle the extra boost OK? Or will it shorten your engines life..?
Old May 30, 2001 | 11:10 PM
Zac's92's Avatar
my car ran better(faster off nitrous) after a couple of bottles? I don't know why. And I do recomend the 5153 kit, I have it on my car.
Zac Spalding
Old May 31, 2001 | 12:53 AM
EVILFACE's Avatar
You guys running NOS, what other mods were done to the engines? Are they mostly stock? About how much time did you shave off?
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
http://www.evilface.com/evilscamaro.htm
Old May 31, 2001 | 02:18 AM
Zac's92's Avatar
I have headers, no cat, and full 3" exaust. Exaust mods are important with all the extra air through the motor. I have a 3.08 posi rear end, hotchkis rear suspention, Open element, injector spacer, pullies,accel ignition stuff,ripper shifter, centerforce dual friction clutch, and a/f and fuel press gauges in the a-pillar. Some other stuff I can't think of. At best I have run a 13.62@110mph(g-tech) so the mph at a track would be 106-107. off nitrous I run 14.80's at 95mph with a best of 14.60 at 97.
Zac Spalding
Old May 31, 2001 | 02:25 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I've been thinking alot about the new Edelbrock nitrous system. Don't know if they make a TB plate or not however.
'91 Camaro RS - dark red metallic - '91-'92 Z28 wheels - leather - all power options (except power seat) - t-tops - Clarion head unit - Pioneer 4way 200watt 6x9s - Rockford Fosgate Punch amp and 2 Fosgate 12" subs - Edelbrock open element w/ K&N filter - Random Technology highflow cat - some free mods, more coming soon...
Old May 31, 2001 | 11:05 PM
BahamutRS's Avatar
I know NOS makes a TBI kit specifically, and they sell it in the Next Gen Camaro/Firebird catalog for $579. No jets included though. It's 125 HP and adjustable, I'm getting it soon
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Pinguiclia
Oct 12, 2015 04:47 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
