Holley 7525 intake and 2" throttle body
Old May 30, 2001 | 04:11 AM
95Z28A4's Avatar
Anyone using this setup with an adapter plate? Is it necessary grind the carb mounting pad for throttle plate clearance? The 7525 seems to have more "meat" for grinding (if necessary) than the Torker II. Also, does the EGR valve clear the 454 TBI IAC?
Thanks,
Mike
Old May 31, 2001 | 08:45 AM
Dan W's Avatar
Yes, 7525 is wide enough for the 2" units.
I'll have to check on the EGR thing.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Old May 31, 2001 | 07:02 PM
JPrevost's Avatar
Car: 91 Red Sled
I can't see how the IAC will get in the way. You'll have a 1" spacer/adaptor so that will only give you more room to have EGR. I'm running the holley 2" and adaptor plate on an RPM intake, no problems except for bending fuel lines a little.
, Jon (350 TBI!)
91 Red My website
Old Jun 1, 2001 | 08:38 AM
95Z28A4's Avatar
Thanks for the info guys.
Jon:
Are you using a 1" spacer under the stock Camaro hood? What air breather are you using?
Mike
[This message has been edited by 95Z28A4 (edited June 01, 2001).]
Old Jun 3, 2001 | 09:07 PM
JPrevost's Avatar
Car: 91 Red Sled
Mike, I'm using an edelcrock pro blow (edelbrock "proflow"). I had to jack up the hood (adjust nuts front and rear) and cut out some underbracing under the stock hood. It was a PITA but I have the RPM intake which has a higher than stock (and performer) manifold. I also had to modify the air cleaner because the inside brace for the foam element was hitting the top of the injectors. There is no way to secure the air cleaner to the TB unit so I leave it resting on top. Oh well, good enough for now until I get a cowl hood.
, Jon (350 TBI!)
91 Red My website
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
