How do I get my car to run less rich??
Old Jun 6, 2001 | 06:28 PM
MurphsIroc's Avatar
I have brown dark smoke commin out the tailpipes, Runnin rich I think, I dont know if i need an o2 sensor but i want to run less righ, i fail inspection for visible smoke, it might be my valve seals but please help me out. Thanks
Old Jun 6, 2001 | 06:48 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
rich is black smoke, better check it out in some more detail. pop the hood. do some testing with your volt ohm meter on the o2 etc..
Old Jun 6, 2001 | 06:54 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like you have a bigger problem than just running rich. I have't seen black smoke come out of any car that runs rich. The only thing that comes out is wet unburnt gas and some carbon (at least on the cars I've worked on). Take the car to a local shop, I can't even think of where to beggin. Have you checked ALL your fluids? How about drive quality, ruff idle, HUGE delay, no throttle responce, what what what. Just smoke?!!?!?! If it's just smoke then I can only think that it's blue (oil).
, Jon (350 TBI!)
91 Red My website
Old Jun 6, 2001 | 07:49 PM
MurphsIroc's Avatar
Throttle Response is good, the ride is great, everything seems to be ok, oil just changed, still on full when i checked today, The only think that is low is the coolant, I think I have a small coolant leak, not sure. The only thing wrong is this smoke problem. Thanks alot, REPLY!!
Old Jun 6, 2001 | 08:17 PM
steve8586iroc's Avatar
Can you say head gasket? I hope this isn't the problem but when you said coolant is getting low, well what else comes to mind.
Steve
Old Jun 6, 2001 | 10:35 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
If it is a head gasket, take ur car out for a ride and let it get hot, just like a normal drive. Then take it back to ur place and when u turn off the engine hurry and pop the hood and look at ur reserve tank to see if there are any air bubbles. If there is, chances are its a blown head gasket. Have u tried posting this on the General Engine/Tech section of this forum? They might have a better idea of ur problem.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
