Air temperature sensor
Old Jun 7, 2001 | 10:02 AM
Keith5's Avatar
Car: C1500
When the Air Temperature sensor is put in a colder place to give more power how exactly is it supposed to do that?
Does it tell the computer to richen a little?
Old Jun 7, 2001 | 12:55 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
The computer will richen the mixture when it senses the lower tep. I used a resister in mine to lower it to about 56*
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old Jun 8, 2001 | 01:04 AM
rsilver's Avatar
Someone told me that the ATS also tells the computer to retard timing when the air gets hot. Is that true in addition to changing the mixture??
If so, then open element guys should relocate
the ATS to a colder place? Sorry to be dumb on this..............bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Jun 8, 2001 | 01:21 AM
JPrevost's Avatar
Car: 91 Red Sled
I don't know if the IAT sensor retards knock but it could. That would be a good question to ask Grumpy over on the Eprom board. The whole idea about using a resistor is to make the ecm think the air is cooler = more fuel. It's a way for somebody to do mods to our speed density setup and not require a custom chip. It helps will little things like the open element and exhaust work, if you change intake manifold, cam, heads, any stuff like that then you wouldn't be able to "tune" with the resistor trick.
, Jon (350 TBI!)
91 Red My website
Old Jun 8, 2001 | 09:43 AM
Keith5's Avatar
Car: C1500
What temperature would it need to think it was to help with a set of headers?
Old Jun 8, 2001 | 04:14 PM
RGZWS6's Avatar
Im using an 8.2 ohm resistor with headers and it really made a difference. I originally made a mistake and installed a 4.7. OUCH! The thing ran like POOP!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N Open Element, Headers, 3in Flowmaster, Pullies, 1.6 full roller rockers, B&M trans cooler,
3.73 Richmond gears and SLP Zexel Torsen Posi (MAY 01), Wonder Bar
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
92purpz28
Aug 11, 2015 02:30 PM
