went racin!!
Old Jun 6, 2001 | 11:32 PM
91rscruiser's Avatar
went racin!!
well i went racing for the first time tonight,and i was very very pleased with my cars performance.as you can read from my signature,i am completely stock except for the flowmaster muffler,which really doesnt do anything except make my car sound good(atleast till i do an exhaust system and better induction).it ran a best of 16.248@84.70mph,60ft 2.36(remember,stock 2.73 gears),with a temp of 57 degrees,75% humidity,and barometer at 29.90 inches.i shifted manually at around 5300rpm,and just got into third gear at the finish line.i was really pleased with the performance,it being "only an RS" and all,stock to boot!cant wait till i get my new manifold and valvetrain now!!damn i need to win the lottery!!well just thought i would let ya'll know.goodnight!
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,th700r4,only mod for now is a flowmaster 80 series replacement muffler.
Old Jun 7, 2001 | 02:22 PM
NJ SPEEDER's Avatar
that is pretty good for a stock car. that mph could be in the high 15's if you could hook a little bit better.
good work.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jun 7, 2001 | 07:45 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just a hint 91rs,
I gotta 92 with a little more mods than you and have been to the track a few times. I found out, by trying it, that if you just let the car shift itself, you run a little quicker. Our cams run outta flow at around 4500-4800rpms. I haven't been since I did my mods, and my best time is a 16.99, but later I found out that my throttle cable had slipped outta the rubber tubing, and was binding up. It wouldn't let the butterfly open all the way. But that was the only time I ran that fast (or slow) , by letting the car shift itself.
If you experiment with letting the car shift itself, you might be surprised. Not that it'll always work though. Just a little FYI
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old Jun 7, 2001 | 07:49 PM
Keith5's Avatar
Car: C1500
I picked up 2 tenths shifting myself.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-velcro t-top bag
-Wonder Bar from my IROC
*****Possible future mods*****
4th gen seats, fiberglass spoiler, new paint
1985 IROC-Z, TPI Auto
-Accel Super Coil
engine and tranny overhauls coming this summer
http://www.geocities.com/krt80/
Old Jun 12, 2001 | 03:10 PM
NJ SPEEDER's Avatar
at this point shifting the car myself is worth 3 to 5 tenths depending on weather. the hotter it is the less of a difference it makes.
lata
tim
14.209@95.46mph
Best 60' 1.917
Old Jun 12, 2001 | 10:41 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Transmission: TH-700R4
I put mine in drive and it goes through the trap at 86 mph at 5500 RPM in second gear. i have never seen third in the quater and still with very little mods ran a 15.86. What would make my car shift to third at 5000 like it should. Even when I shift it manualy to third it stays in second till 5500+.
91 RS 700R4. Open Element and Ultra Flow Muffler. ET 15.86
55 Chevy on 76 4x4 frame
Old Jun 12, 2001 | 10:43 PM
AJ_92RS's Avatar
Well I didn't say it always worked. I had a 94 Z28 LT1 6spd that I pulled my best times by shifting at 5200rpm instead of the 5800 redline. SO NAH!!! HEHE!! Plus I read in CHP, MotorTrend, Car Craft, etc., that taking off at idle was best for that car. Well I pulled that same time by easing out the clutch at 2000 rpm. Probably due to my lack of expert drag racing. The only mod I had on that car was a Flowmaster muffler (not a cat-back, they didn't make it yet) and a K&N filter.
It's just that he said his car was basically stock. Your cars aren't. Once I get my car back to the track, I will experiment. Now that I got mods, it may be better for me to shift later now too. I was just trying to help
mitch_04
20
Apr 4, 2015 04:27 PM
rffanat1c
Aug 7, 2014 06:07 PM
xxbrew1690xx
Third Gen Fest '15
May 20, 2013 12:16 PM
bandit45
Jul 11, 2002 10:30 AM
