Open Element??
Old Jun 8, 2001 | 03:58 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Open Element??
I have a stock 305 TBI Firebird. I have an open element filter sitting around. Will it wirk with a stock hood? i thought a cowl hood, or something that would let air in was needed. I know it would help greatly, but will it do better than a stock intake without the aftermarket hood?
Old Jun 8, 2001 | 04:08 PM
JPrevost's Avatar
Car: 91 Red Sled
YES
, Jon (350 TBI!)
91 Red My website
Old Jun 10, 2001 | 01:01 PM
TZFBird's Avatar
Engine: 327
So, adding an O/E will increase my performanc..Yes. But will this require a better exhaust system? Or will it just add to a point and then stop because of the lack of flow for the exhaust. I am debating on headers, but I want the easiest and cheapest ones to install.
Old Jun 10, 2001 | 01:42 PM
EVILFACE's Avatar
It'll give you a small boost, but nothing that would require updating the exhaust.
Evil's 88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element, MAC Lower Control Arms and Panhard bar
[This message has been edited by EVILFACE (edited June 10, 2001).]
Old Jun 10, 2001 | 06:21 PM
OldBlue's Avatar
Ive been looking for headers myself and found a pair of heddman headers w/ AIR for $300
Old Jun 11, 2001 | 12:19 PM
TZFBird's Avatar
Engine: 327
Well, the whole assymbly in general is too small to fit on my engine. So, I need to buy one. What do you guys recommend? I know K&N is good, but does that come with the filter and base for it?
Old Jun 11, 2001 | 12:44 PM
RyanSS's Avatar
Here's what I did:
went to Advanced Auto parts and bought a Mr.gasget 14" NON-drop base air cleaner with a paper 2in element (pn 1480) then I bought a 3" K&N filter (pn E-1650) to go in it.
It looks and flows great.
It set me back about $70.
Oh, I drilled out a hole in the bottom of the base for the IAT sensor.
To use a NON-drop base, you have to remove that little spacer thing on the throttle body.
89 RS (supposed 350) TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
Old Jun 11, 2001 | 12:51 PM
RGZWS6's Avatar
Get the Summit 14x3 non-drop with their version of the K&N (same thing) for 39.95 and relocate you IAT sensor to the firewall somewhere cool
89 Formula 305 TBI
160* Stat, 200* Fan Switch, K&N Open Element, Headers, 3in Flowmaster, Pullies, 1.6 Full Roller Rockers, B&M Trans Cooler, Wonder Bar
3.73 Richmond Gears & SLP Zexel Torsen Posi ----Still Waiting To Install----
Old Jun 11, 2001 | 07:25 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Whoa, RyanSS, you could have gotten a real K&N Chrome OE 14X3 for that price.
Old Jun 11, 2001 | 09:41 PM
TZFBird's Avatar
Engine: 327
I tried removing the IAT sensor tonight, but it is in the filter housing very tightly. I was not able to get it out. Are these sensors very expencive? Will buying one instead be worth it?
Old Jun 12, 2001 | 03:55 PM
RGZWS6's Avatar
You could always replace it wit a resistor. The tech article reccomends a 7.5 I believe but a friend of mine only had an 8.2 laying around instead. It works great! The higher up in resistance you go the colder the ECM thinks the air is. I made a mistake at first and put in a 4.7. OUCH! Needless to say I replaced it with the 8.2
Old Jun 12, 2001 | 07:42 PM
One Eyed Jack's Avatar
I want a K&N Filtered open element air cleaner. Wheres the best deal? Jegs? Summit? Local CarQuest? How much would it run me? What does NON-DROP mean? GAHHH just pick something for me :P
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 14, 2001 | 12:53 PM
92Camaro305TBI's Avatar
http://store.summitracing.com/..... Or www.summitracing.com ; www.jegs.com i believe open element is also know as air cleaner if someone could back me up on that. best deal ive seen at summit for $20
92 Camaro 305 TBI Automatic. Everything stock so far except a shift kit.
Future mods. Spark plug wires and plugs, tint, new 3inch pipes. Maybe putting 2 glass paks for effect. any other advise on getting to 300+ HP would be appreciated. Thanks
Old Jun 14, 2001 | 06:25 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
One Eye, non drop means the base of the open element air cleaner is not "dropped". You know how our stock air cleaners are sitting on top of a spacer ring and then it drops to the level that the filter itself fits on? Well, that's like a drop base. Basically, you can use drop base or non drop base on our cars. If you use a drop base you leave that spacer ring on. If you use a non drop base, take the spacer ring off. You may run into clearance issues with the coil, but that can easily be adjusted by bending the bracket. I'm guessing clearance would also depend on the manufacturer as well. As far as for which one to pick . . . you're on your own. You will get mixed decisions if you ask this board. Summit would probably be the cheapest place to order a specific one. Auto parts stores carries them as well and the filter can always be swapped with a real K&N.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
