How much more power
Old Jun 4, 2001 | 11:13 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
How much more power
if i added some ported late model(1989) 350 heads, a LT1 cam, and a edelbrock tbi intake to my 305 TBI
right now i got a open element and a high flow cat with flowmaster(a exhaust cut-out before all that) and the ultimate TBI mods
how much is the LT1 cam with all the stuff i would need to install it???
[This message has been edited by brodyscamaro (edited June 04, 2001).]
Old Jun 5, 2001 | 08:17 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
290hp-325 engine hp. really depends on heads and intake. that cam is theoretically nice for our engines, could be good for 30hp alone with new springs too.
Old Jun 5, 2001 | 02:10 PM
steve8586iroc's Avatar
Brody, if you want to use the 350 heads you will have to mill them a lot. You would be better off IMO to use 305tpi heads or L98 aluminum heads off a Corvette. These heads have the correct 58cc combustion chambers to keep the compression ratio the same as stock.
Steve
Old Jun 5, 2001 | 07:09 PM
Milling is no problem(unless they have to be milled too much) 64cc(??)to 58cc is that reasonable? Anyone know the cost of a new LT1 cam and/or L98 heads? I appreciate all of the information!!! What is a good intake for this combination? I was just wondering should I do all this engine work or just get 3.42 gears and a posi? Basically I am wondering the best bang for the buck? Thanks
[This message has been edited by brodyscamaro (edited June 05, 2001).]
Old Jun 6, 2001 | 06:39 PM
snflupigus's Avatar
bang for buck. vortec heads = 408 + 50 for gaskets + manifold @ 230 for vortec heads, + tuning tbi + 70 to mill the vortec heads.
i would get posi, but its not going to as much bang.
option two, get s/r torquers heads @ 599, regular manifold at $90, gaskets, tuning tbi.
rearend, 3:42 gears and install. $350-400?
Old Jun 10, 2001 | 12:34 PM
CamaroLuvnPunk's Avatar
<font face="Verdana, Arial" size="2">How much is the LT1 cam with all the stuff i would need to install it???
[This message has been edited by brodyscamaro (edited June 04, 2001).][/B]</font>
WAIT A SECOND?? Can you put a 350 LT1 Cam into a 305 TBI?!?!?! What needs to be done inorder to make it work and what would be the best heads and intak combo?
Erik
Old Jun 10, 2001 | 04:27 PM
ahusted's Avatar
Who all here is running a set up close to this, and how does it work? My father-inlaw and I are thinking about building one of these on the cheap!! We found a pretty clean 88 RS Lo3 5sp $2100, You Pull It rear 3.42s(open)$50, used LT1 cam free out of my 97 Z, used 305 TPI heads $125, FlowMaster 80 (Junkyard buy!!) $8, gasket set Felpro $80. Thats the main stuff and then all the little free things. Is this a good idea? What do you guys think? Oh, Snflupigus I am finding true bang for the buck is a used vortec motor out of a '96 to '98 GM truck platform. Around here they go for $1100-$1300 complete with 30,000 mi on them. If your going to spend $500 on vortec heads, might as well pony up $600 more for a 350 that you won't even have to pull the valve covers on!!!!(Remember Badbird?)
Old Jun 10, 2001 | 08:01 PM
4-bolt's Avatar
I am running a 350 tbi in a '87 truck. Here is a list of what I have done.
350 4 bolt main bored .040 over
domed pistons for 9.5:1 CR
Ported and polished heads with larger valves
268H Comp cams cam and top end
Flowtech headers
3.73s on a Detroit locker
Stock TBI
Stock intake
Exhaust is 3" custom Y pipe, 3" cat, 3" in/dual 2.5" out
Stock Computer
The 268H cam is recomended for modified computers, but I can't bring myself to buy a chip now and still have to buy a custom chip later. I had 3.42s with an open diff. up until about two months ago. With the 3.42s My 4500 lbs truck could beat a 2000 Mustwang GT by a full car length to 65 mph, with traction problems. The 2000 GTs are running mid 14s in the 1/4. I thought that this might be able to give you guys a clue as to some real world comparisons on a similar set up. I haven't had the pleasure of running a GT after the gear change.
Old Jun 10, 2001 | 09:21 PM
bigvic's Avatar
4-bolt,
Im just curious, how steetable is that combination of yours? Does it make for a good daily driver? What kind of milage are you getting, and how does your stock computer react with that 268 cam?
Im wondering, because I am about to buy a chevy truck with the same engine platform as yours, and Im trying to come up with a good streetable daily driver combo that gets decent gas milage, but can still kick some A$$ on occasion.
Also, do you know of some chevy truck message boards that are as high quality as Thirdgen? I have found a couple, but they are really sucky and hard to navigate.
Old Jun 10, 2001 | 09:29 PM
4-bolt's Avatar
It is very streetable. The computer isn't very happy. I had to adjust the iac, and with this cam and a stock computer there just isn't enough timing advance. I started running with a 160 t-stat, but had to change to a 180, because with the 160 I couldn't run on premium fuel without stalling at idle in gear. I still don't run premium, but I knew that it was still a problem. It responds much better with 180.
The best truck site I have found is www.sportruck.com
The guys over there are very helpful and know there stuff. I am glad I found this site because there is a bunch of TBI info here.
Old Jun 10, 2001 | 09:44 PM
4-bolt's Avatar
Ooops. I get about 12 mpg if I can keep my foot off the floor.
Old Jun 11, 2001 | 06:35 PM
bigred305's Avatar
Hey 4-bolt, it is good to see some of my TBI buddies from sportruck.com making it over here. This sight is very helpful, and I am constantly learning new tricks for our motors on here. Hey did you ever figure out the price of shipping?
87 C-10
305 TBI
(yeah I know its a truck, but you are the best TBI guys I have found)
Performance
**Somewhere around a 17.0 @ 85 ish (G-Tech)
*Freshly rebuilt 305 bored +0.030 over (311)
*K&N Airfilter
*Homemade Ramair w/ modified intake
*180 thermostat
*Custom True dual exhaust(Flowmaster 40's)No Cat's
*TD Performance TBI Spacer
*Mobil 1 10-w30
*Redline Water Wetter
**(alot more done, but I don't feel like boring everybody)
Old Jun 11, 2001 | 06:59 PM
4-bolt's Avatar
Whassup? Nah, I have been extremely busy at work. Between work and swimming around Houston J/K I have been taxed for time, but I should be able to do that tomorrow. Some of these guys make the TBI truckers look like we are still trying to figure out what the "wheel" is.
I was just reading about programming proms. Hmmmm? What else can I tear up?
Old Jun 14, 2001 | 06:38 PM
LT1 cam with torker II intake
VERY mildly ported stock heads w/ new springs
good combo??
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
