Fuel Pump and TPS adjustments
Old Jun 27, 2001 | 10:42 PM
Nosanity's Avatar
I have an 82 Trans Am crossfire injection. Is there a much easier way to replace the Fuel Pump without removing almost everything to get to it?
Also, if anyone knows the adjustments to the TPS, please let me know. I get a little smoke when I start the TA.
Thanks!
1982 Pontiac Firebird Trans Am
305 V8 Cross-Fire Injection
Old Jun 27, 2001 | 11:43 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Just drop the axle for the fuel pump.
You could cut a hole from the top, but thats not the right way and since the tank is about an inch underneath you could puncture it and blow your self up.
The TPS has nothing to do with the smoke. Thats bad valve seals, but not enough to worry about.
Old Jun 29, 2001 | 12:41 AM
Nosanity's Avatar
The smoke started when we put in the TPS, I haven't noticed any before we replaced it. The only thing im wondering is when warmed up at a dead stop, I keep hearing extra beats from the rear end area. When you hear the idle, there's an extra beat, seems like it's not timed right, but it is. Any suggestions?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
