if i remove my AC pully on my 85 TA lb9 would i feel a performance increase??
im not even sure i can do this but i hear i can free up to as much as 10-15 hp doing this alone, is it possible to just take off the pully or would i need an idler pully for it? just curious....
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
89,
As long as the AC is turned off, all you really have there is an idler sheave.
Removing the belt will gain you approximatly 3/100ths of a horsepower...it's only a little worse than removing the AIR pump belt.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
well first off guys sorry for posting a TPI question in the TBI forum, i was unsure what the increase would be but it seems that it wouldnt be worth the time to do so, who knows ill read into it some more, i doubt ill bother though, thanx alot guys
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
If it doesn't work I would remove it. It it does, leave it on.
My compressor leaks (found out after spending 200 convreting it to the R134), so I'll probably remove it as well.
I've already removed the smog pump and if I remove the AC, I really wont need that entire AC/Smog mounted on the front of the block except for the spring tension. Hmmm how to remove that and keep it serpentine.
Evil's 88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element, MAC Lower Control Arms and Panhard bar
Evil's 88 Camaro
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
hey its 94 today in omaha, wish i had ac controls. i got working ac but no controls right now. anyway. if you dont want the ac coming on sometime, just rig a switch to shut the compressor of manually. ive seen a 3 cylinder geo do this, it was like a nos button when he hit the switch, but in your case, its not robbing you of that much hp.
if you wont ever need it or want it again, sure take it off. but if you want it in 3 or even 4 years maybe. i would leave it. besides, its kinda hard to sell a car with out ac too.
just un plug the plugs on the compressor, and youll have removed what you need to.
removing 40lbs, is what. .03 seconds in the quarter.
none of the aftermarket serpentine belt systems use a spring tensioner. if you really want to delete it I think you just rig up an adjustable bar to the slternator or something so you can tighten the belt. I'd leave it though.
Car: 88 IROC
Transmission: auto
I removed mine cause it made so much more room in the engine bay, and it makes is sooo much easier to work on stuff. It was a breaze to put my headers in without it. I never use it anyways.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.2s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
what about removeing the smog pump? i dont plan on doing this to my car but my friend does with his LG4, would it be worth it? we already removed the AC today, minimal increase in performance but alot cleaner under the hood.
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Removing the whole smog setup (air pump, all hoses, etc) wont give you much of a performance gain...
But under the hood will look thousands of times better. The car will be MUCH easier to work on, too. Plugs become an hour job
Too bad we have E*Check in OH, so I cant get rid of it... but rumor is that its going away in 2k5.
Chuck Kulchar
1991 RS
Chuck Kulchar
1991 RS
Car: 91 Red Sled
Chuck, I go to OSU and nobody there had any e-checks. I live in NJ but that's besides the point. I thought Ohio was really lax about that stuff, just keep it registered and give them money. Besides, all Ohio's crap air gets blown over NJ anyways....what do you guys care
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
NBrehm
Aug 25, 2015 11:49 PM
