JPrevost!!!! ANYBODY Lean or Fuel Pressure
Old Jun 15, 2001 | 08:17 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Listen a guy from Icon motorsports from the Tech Board said I may have a lean condition. It will pick up speed slow with no POP in the TBI........But if you give it throttle fast it will POP in the TBI but still has no Power. What is the factory PSI my inline meter should read. This is killing me being so close.
THANKS FOR EVERYTHING
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old Jun 16, 2001 | 12:42 AM
JPrevost's Avatar
Car: 91 Red Sled
Brian, I think it is a lean condition. I tried to make my car have the same problems as you and when I got it to run lean was when I had the problems with quick throttle. It idled fine, a little choppy but it did, then when I slowely get going it stumbles a little. If I stomp on it the thing almost quits and BANG big backfire! This sounds exactly like what you're problems, at least that's what I remember when I was there. You definatly are going to be running lean with 40 injectors, stock fuel pressure and stock chip!
I talked to Kyle yesterday, he called, I told him that I have some solutions for "tuning" and he'll tell you about it.
For right now crank up that fuel pressure a LOT. Like 15 or even more. See if it gets better. It'll probably run really rich at idle but the "problems" should be less noticable when you give it some throttle.
E-mail me your addy and I'll send out a chip for you that has a richer fuel curve. Just tell me if it's running really rich at idle or not. The chip I burn for you might not be perfect but it should be a LOT better than the stock unit for your combo. I'll keep everything stock except for pumpshot, VE table, and injector constant.
I would bet money that it's a lean condition after watching how my engine reacted to a lean eprom.
, Jon (350 TBI!)
91 Red My website
Old Jun 16, 2001 | 01:15 AM
Kyle F's Avatar
John that sounds great. I truied to tell Brian to get some larger injectors off a 350 or something, but he siad he is going to make the adjustable fuel pressure regulator first and see if that helps. I forgot that you can make you car lean like that from programming a chip. Thank you, man that is so cool you will have to help me learn to do that once I get my car back together.
Remember I said back a long time ago that I thougt it was doiong it because it was so lean? MAybe you hadn't been ther yet, ut I said this a long time ago. Anywho the being rich and blowing black smoke was what made Brian believe it wasn't true, but that was only at Idle and I tried to tell him that there was just not enough fuel whn you open the throttle fast.
If you can program that chip just like yours and make it rich as hell because you engine should have abouty the smae needs as Brians with the Cam and heads allowing it to flow som much better. I mean its just my suggestion, but it seems to make sense that yyour and his would have similar needs and his chip would just have to big over on the rich side.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 17, 2001 | 10:58 PM
idrag2's Avatar
I'm having about the same problem as well, but mine is Popping around 4700k could a lean problem cause this too??? And if so I have a 454 TBI unit in the garage if I change the injectors out from my LO3 to the 454 would this help????
I drag 2
Old Jun 17, 2001 | 11:15 PM
JPrevost's Avatar
Car: 91 Red Sled
The 454 injectors are twice the size of the stock 305's. They are WAY too big. You need some 55 MAYBE. Just bump up the fuel pressure for now. That should fix your top end BUT the Lo3 doesn't like high rpms anyways. If you have stock cam and rockers then that is you're problem, not the fuel.
, Jon (350 TBI!)
91 Red My website
Old Jun 18, 2001 | 03:10 PM
idrag2's Avatar
well check this out I have comp roller tip rockers 1.6 ratio and if it was my valvetrain would it not do it every time. It only does it once in awhile.....
Old Jun 19, 2001 | 03:33 AM
JPrevost's Avatar
Car: 91 Red Sled
Change your fuel filter lately? Good idea if you can't remember the last time. If you think it is running lean and not getting any fuel up top then romp on it until it acts up then turn the key to off and coast to the side of the road. Pop hood and check the spark plugs.
, Jon (350 TBI!)
91 Red My website
Old Jul 1, 2001 | 05:16 PM
EROCK's Avatar
I just replaced my fuel pump (holly unit...something like twice the flow) and the filter. It SEVERELY dropped me in time at the strip but my plugs are still white like they are not getting enough fuel. I changed them after I changed the pump so I know that they were not white still from before. How do I get my car to run richer? I did not understand in the tech article how to get mine adjustable. It is also an aftermarket chip that is supposedly giving it more fuel. Any advice will be of great appreciation. Thanks
Eric
Gitarz2@yahoo.com
Teal 1991 Camaro R.S., T-Tops,
Leather, Re-worked 700r4 also w/kit,
MSD ignition, MSD 8.5 mm. superconductor wires,
MSD Coil, ADS superchip, Open element air cleaner,
K-n-N filter, Gutted cat, Flowmaster cat-back system,
Edelbrock TES headers, March 3piece billet underdrive pulleys
3.73 gears
http://www.geocities.com/gitarz2/camaro.html
I was shocked to see that companies sold a taillight
set for a rustang! Since when do they have taillights????
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
