Car still running bad....PLEASE HELP!
Old Mar 20, 2007 | 12:34 AM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Ok so i replaced my TPS because when i unplugged it it ran perfect, well whenever it's plugged in, both the new and old TPS make it run crappy, when unplugged, runs perfect but check engine light's on. With either of them in , it's off. It Idles high and jumps around at a idle from around 1000 to 2000 and stays at 2000 sometimes if it feels like it, and this is warmed up. With the TPS plugged in it also stalls out and runs aweful. I was thinking could my IAC be bad even with no check engine light? Anything else I should know about that could be causing this?
When I plug in the tps and reset the computer and run a scan, it finds that everything is working perfect, both with my chip reader and the mechanics shop i went to.
I replaced the fuel filter and the gas is brand new.
BTW: I just installed all new gaskets and injectors in my tbi unit and it's still running exactly the same which makes me feel as if i wasted my money
Also what is the order on the dist. cap. I'm just wondereing for further removal.
Any help is greatly appreciated because I just got my car registered and now it's not running right so i can't even drive her...:-(
Old Mar 20, 2007 | 07:41 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It definatly could be the IAC from the sound of it. It certainly couldn't hurt to replace it. The ECM wont set a code with a bad IAC. Only the later computers set a code if the counts zeros out or the closed loop idle terms wind up.
Old Mar 21, 2007 | 10:05 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
Re: Car still running bad....PLEASE HELP!
nevermind...
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
