Bad Gas?89 into a 305/WTF!!!!!!!!!!!!!!!!!
Old Mar 20, 2007 | 11:24 PM
redline_racing's Avatar
Hello,I was wondering is there anyone who can help me out! yesterday I went to the the gas station and told the attendant that I want $30 on 93 Premium instead on 93 he puts $30 on unleaded(89) car was running good now I can't go up to any speed without it stalling out or putting real bad and going real slow so embrassing but how can I fixed the problem to make this Bird run again right.Please anyone any good information I would gadly appreciate that Thanks Rob
Old Mar 21, 2007 | 01:39 AM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
Re: Bad Gas?89 into a 305/WTF!!!!!!!!!!!!!!!!!
Off the top of my head:
- use a pump to get most of the gas out of tank
- drive it all out
- drop the tank & pour it all out
They sell cheapie little pumps at most auto part stores for taking the gas out of the tank without having to syphen. Look for the longest one that reach all the way to the bottom of the tank, and get as most out as you can. The other two options are pretty self explanatory, but if you really can't drive the car at all I guess option 2 is scratched. Maybe somebody else has another idea I couldn't come up with off the top of my head.
Old Mar 21, 2007 | 01:03 PM
ran gas out people told me it could be the timming needs to be adjusted,maybe fuel filter,the iac,map sensor really need help and would the iac cause the car to run bad like that?thanks
Old Mar 21, 2007 | 01:27 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Unless you have made some major modifications to your engine (I.E. high compression, cranked timing) your engine should run better on 87 than 93. The stock compression ratio just doesn't need the higher octane and will even make more power on 87.
Old Mar 22, 2007 | 06:19 AM
IROZINCO's Avatar
It sounds like maybe you just got bad gas (water in tank) 2 things
empty a can of dry gas into it. Rock the car up and down a few times to slosh it all around and then let it sit for about an hour. Try running it then. If that doesn't fix it then:
Get some octane booster. Put that in there and repeat above procedure. If neither of those fixes the problem, then you have a really big coincidence, and something else just broke.
But it really does sound to me like bad gas, which some drygas will fix.
Old Mar 22, 2007 | 07:30 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
bad fuel pump? check your fuel pressure.
Old Mar 22, 2007 | 12:03 PM
feule pump is new so i dont know what the f$#$ is going on at all i need help anyone close to pa that could come and help me !!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 24, 2007 | 12:24 AM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Yeah, those sketchy gas stationd get water in their tanks, I remember one time I put 91 in my tank, and felt so ripped of because it was a huge waste of money, and ran the same. Don't put 91 in a 305 TBI, it's not a high performance machine, 91 is for high performance machines.
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
