I think my car has ignition related trouble; help needed. . .
Old Jul 23, 2001 | 02:24 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
My car has been running great for a while now, but today was the end of that streak. I don't think it's the plugs. They are AC Delco plugs and they are maybe 7000 miles old. Here are the symptoms: the speedo and tach needles both jump around like crazy; at idle the tach jumps up and down about 300 RPM and it used to be solid and dead on; power loss under acceleration; it felt like the engine just cut out and stopped working 3 times then it caught again but was still running rough; feels like there is a HUGE cam in the car and I know it's a peanut; under the hood it smelled funny, almost like a burnt smell; and a click sound coming from near the ignition components by the distributor. The burnt smell immediately made me think "wires". They are very close to the manifold on the driver's side (actually, it's close to the silver colored metal piece that is around the manifold that is used to channel warm air up into the snorkel) but I don't know how to tell if the wires are burnt. They don't look it but then again I'm not sure of what I'm looking for. They look like stock wires also. I changed the rotor about the same time I did the plugs. The cap was in good condition so I didn't change it. I also had the ignition coil tested around the time I changed the plugs and it was good. All help and suggestions will be very much appreciated. Thanks
Old Jul 24, 2001 | 01:19 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
try changing the ignition modulein the dist, that could cause some probs
--Stormr
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2010(soon to be 2031)
B&M shift kit
straight pipe exhaust-with resonator tips
160 thermostat
open element
Old Jul 24, 2001 | 10:08 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Well, it's new already, lol, but maybe I'll try my spare. I'm changing my cap and wires in the moring so I hope that works. Thanks
Old Jul 24, 2001 | 10:21 PM
JeffC1500TBI's Avatar
the speedo jumping around doesn't make sense.. unless you have a bad groud connection..
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
3.73 Rear gear ratio,
Edelbrock performer TBI intake, performer cam, timing chain,
Hiflow cat with Rhino dual 2 1/2" out the rear.
BRoss99
Aug 10, 2025 05:08 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
