TBI and computer swaps
Old Jul 20, 2001 | 04:45 PM
jmp1999's Avatar
I have an 1988 camaro TBI. Now has a 350 in it. I know that a TBI unit from a 454 will fit on it. But will the computer swap into my car. Also, can I put the 454 chip in my stock computer? Anyone tried this?
I'd appreciate any help.
Thanx
Old Jul 20, 2001 | 11:51 PM
Brent's Avatar
The truck 1227747 ECM plugs right in and runs. Will the 454 PROM run well in your car? Doubtful. The 454 has a huge pump shot compared to the stk 350 PROM's. It is also calibrated for the 80lbs injectors.
Old Jul 21, 2001 | 01:11 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
all that you need to do is get a set of the 65 (or 68)lb injectors. Those are usually found on the chevy one ton trucks. Then get a prom from a caprice cop car. I used to have the chip number, but I let someone borrow the receipt and now I don't have the number handy.
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job.
Old Jul 21, 2001 | 12:40 PM
Brent's Avatar
He can't do that without swapping ECM's. He has an '88 with the 8063 ECM. The Caprice used the 8746 ECM.
In addition, the Caprices that ran the 8746 ECM's never had the 65lbs/hr injectors. They ran the 55lbs/hr units.
Old Jul 21, 2001 | 06:10 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
the way it was explained to me, which could very possibly be wrong is that the caprice cop car used a different prom, and #65 injectors. i am about to do the 305 to 350 TBI swap. its not good if these things are incorrect. so far, i know i have to swap ecm's, injectors, and knock sensor. i think the prom number is 1614494. someone off the board gave me this info, he said that he was using it in his 350 TBI swap with a vortech crate motor, i cant remember who though. i was going to do more research on the topic before i started it, now i definately am.
Wide Open Till You See God...Then Brake
Old Jul 21, 2001 | 06:45 PM
Brent's Avatar
The later 5.7L Caprices did come with 65lbs/hr injectors, but they used a different ECM.
Old Jul 21, 2001 | 07:06 PM
LilJayV10's Avatar
Engine: 406 Roller
ok, now this is my question, what ECM and # injector is the best to use in a 350TBI swap?
Old Jul 25, 2001 | 01:38 AM
burntblues's Avatar
Car: 1989 Camaro RS
huh, I figured that his ecm would be close to mine since its only within a year, but the 1989 is sort of an odd ball year for some reason. I can try and find the chip number, but I'm not gonna rip my ECM out for that number, sorry...
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
xkingcodex
Feb 12, 2020 07:43 PM
midge54
Jan 29, 2017 07:00 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
