Turbolink
Old Jul 26, 2001 | 07:11 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Turbolink
I just wanted to tell everybody that I have tried TURBO LINK for the TTA and the T-Type and it worked.......it scanned everything the Auto Xray did...
All you need is the software and a laptop
if you have any questions let me know
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 27, 2001 | 12:16 AM
Brent's Avatar
Any saved logs you care to share?
wildkat@paonline.com
Old Jul 27, 2001 | 02:10 PM
Well not yet...I have to figure how to work it all first and I still have the timing chain problem to fix. Then I hope to share anything that may help.
Still getting 5 knock counts at idle
Brian
1989 Camaro RS
Old Jul 27, 2001 | 04:02 PM
NotDadsW41's Avatar
Knock counts at start up is normal in TL. Remember the Knock Counts just keeps a running total of how much the ECM has seen. Your starter makes alot of noise when you first start the car, hence the counts.
Old Jul 27, 2001 | 07:27 PM
Would that explain why the scan software never goes back to zero.....It stays at 5
Brian
1989 Camaro RS
Old Jul 27, 2001 | 09:07 PM
NotDadsW41's Avatar
Yes. But I think you should see some knock counts as you are driving the car. The computer should always be trying to retard timing during normal cruising until it senses knock while trying to optimize fuel effiency.
All three of the TBI vehicles I have scanned using TL show some knock while driving the car. Of course they all have/had more than 130k miles on them too.
Old Jul 27, 2001 | 10:53 PM
JPrevost's Avatar
Car: 91 Red Sled
My car has yet to turn any knock counts accept for the few at startup. Now I know why....it's because I run higher octane AND burned my own custem eproms! lol
If you aren't getting ANY counts after a long drive (cruise and hard WOT) then you can either program in some more timing OR adjust base timing a bit. The problem with adjusting base timing is the startup. Too much advance that the car will have a hard time starting.
, Jon (350 TBI!)
91 Red My website
Shookum2004
Sep 17, 2007 01:00 PM
Swapmaster
Feb 28, 2003 03:32 PM
RedIrocZ-28
Aug 11, 2002 04:56 PM
Kyle F
Nov 11, 2001 03:56 PM
Kyle F
May 22, 2001 07:15 PM
