TBI FAQ SITE. input your commonly seen questions and answers to those questions here
Old Jul 29, 2001 | 10:33 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
so that i can put up a site linked from the top of the page, like the diy board. for all the new guys asking the same questions. it will help them get their answers quicker, and us veterans with our typing time and helping others with not so regular questions.
ill start to show how i think a post here would work best to be added to as site later.
Old Jul 29, 2001 | 10:35 PM
snflupigus's Avatar
QUESTIONS :
can i put a 454 aka 2" throttle body on a stock 305
ANSWER:
yes, it can be done. fuel pressure increase is a must however, ive been working with the idea for a while, on and off the car etc..
results. 454tbi with slight increase in pressure caused the car to still run lean, increasing knock counts, retarding timing, decreasing milage drastically, and causing a lag off idle acceleration, which made my car seem like it had an higher stall converter, spin the tires and seemed to rev faster, but the minute i would get knock, the cars acceleration would die out as rpm increased, if cruising at 60, the ecm would correct the mixture, acceleration from hwy cruising was increased. all in all, chip changes are probably a necessity if you want a 454tbi on a stock or barely modified l03.
Old Jul 29, 2001 | 10:37 PM
snflupigus's Avatar
QUESTION:
how do i install an open element air cleaner, and what will it do for me
ANSWER:
http://snflupigus.tripod.com/step1.htm
getting the picture?
your turn.
lets get at least 5 more like
"whats the first think i should do to my l03?"
and
"what should i expect from my tbi car?"
or
"how do i adjust my fuel pressure"
etc....
Old Jul 30, 2001 | 12:17 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
OK. Here's one I see a lot, but gets different responses every time.
"What is the factory CFM of a TB on an 305? Or 350? Or 454?"
Now I've read an article in Hot Rod Mag. that the factory cfm rating on a 305 and 350 TB are the same, GM just used different injectors. According to Turbo City, the stock cfm rating is 535cfm (585cfm for their modified one). And a stock 454 TB is 620cfm. But on here I've read on the 305 it's 485, or 435, or 385, etc., etc., & different on the 350s, etc. It's different every time.
Someone needs to look this up somehow and confirm the ACTUAL flow rate of these TB units. Call GM or something & get actual #s and flow rates. Or possibly bench flow them before and after the "Ultimate TBI" mods. Even that alone would help answer a lot of questions.
Old Jul 30, 2001 | 01:08 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Here's my thoughts...
1) What is best ignition timing for stock LO3?
I went through the archives and there were quite a few differences, but it seems like most think 3* to 4* is best if you don't use premium, and then 6* to 8* with premium but then there was concern about the knock sensor...which seems to me wouldn't be a problem with premium....
You guys are far more knowlegable on TBI's than myself.
1997 Chevrolet Camaro SS # 379
1992 Pontiac Firebird Formula
1973 Chevrolet Camaro RS/Z28
1969 Chevrolet Camaro SS 350
I miss seeing the sun shine down on the black #3 car.
I'm old enough to know better, but still too young to care!--Wade Hayes
Old Jul 30, 2001 | 01:47 AM
Tas's Avatar
Tas
topic. LT1/LT4 cam in TBI engine.
https://www.thirdgen.org/messgboard/...ML/002123.html
also add: ZZ4 cam is too big, you don't NEED 1.6 roller rockers with any of them.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 30, 2001 | 09:02 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
To add to the open element, some people still will ask whether to go with drop or non drop. Some people just want to be told what to do. May I suggest getting a list from all TBI users with OE's to name the brand and the trouble (if any) they encountered installing it. That might be helpful for new members.
Old Jul 30, 2001 | 02:25 PM
scauffiel's Avatar
On my site I've got pages on:
Spacers - http://www.transamtemple.com/modifications/spacers.htm
Making the fuel pressure reg adjustable - http://www.transamtemple.com/modific...re_regulat.htm
A couple of pix of FP gauge install - http://www.transamtemple.com/modific...ge_install.htm
And an exploded view of the TBI itself - http://www.transamtemple.com/modific...on_rebuild.htm
You're welcome to use any of the stuff off of my site for the FAQ.
Steve
Steve's Trans Am Temple
Old Jul 30, 2001 | 05:56 PM
TMoNeE's Avatar
Car: 87 Z28
<font face="Verdana, Arial" size="2">Originally posted by soulbounder:
To add to the open element, some people still will ask whether to go with drop or non drop. Some people just want to be told what to do. May I suggest getting a list from all TBI users with OE's to name the brand and the trouble (if any) they encountered installing it. That might be helpful for new members.</font>
Ive got the edelbrock 14x2 non-drop and i had no problems
MustangBeater20
Oct 29, 2022 09:20 PM
Thornburg
Aug 25, 2015 01:46 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
