350 tbi help from 93 Sierra
Old Jul 26, 2001 | 12:14 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
My dad's truck has the 350 tbi in it and when he starts it sometimes after it's been running he has to give it gas in order to keep it from dying out. I starts to sputter and wants to die out.
We think its the EGR? It was tuned up less than 10000 miles ago. Possibly an 02 sensor?
Any help? Thanks!
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
3" cat and Force II cat-back
Old Jul 26, 2001 | 01:01 PM
FastBroker's Avatar
I would check the ECU for codes and ALL THE HOSES IN THE engine compartment for vac leaks. Also, if you JUST did aything to the engine/truck, that would be suspect, too.
Old Jul 26, 2001 | 07:41 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
My dad replaced the hoses when he tuned it up, and the only thing he had to change recently was the water pump, but that's been on for a month. Perhaps it is a vac leak... damn vac lines
Thanks!
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
Old Jul 27, 2001 | 09:48 AM
FastBroker's Avatar
Check for codes, too. As said in Animal House, "Don't cost nuthin'!"
Old Jul 27, 2001 | 09:42 PM
ChevelleCLM's Avatar
TPS?
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
Old Jul 28, 2001 | 02:33 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Thanks again everyone. It didnt throw any codes and we checked 'er today for leaks, but to no avail. I think tomorrow he's gonna play with the egr, see whats going on.
But I can say that its been one kick *** motor. 130k miles with only a new alternator, water pump, and starter (ironically the same three things I've replaced on my car). Runs like it has 5 miles on it, and he's done his share of towing and hauling for his work (industrial tools salesman). Couldnt have asked for a better engine.
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
Old Jul 28, 2001 | 11:31 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Your going to want to check the Idle Air Control (IAC). I just helped a friend last night with his '92 Chevy truck's sputtering problem. I pulled out the IAC and it was seized, it wouldn't move at all! It's supposed to srcew in & out with air demands of the engine. Got it to move with some pliers, put it back in and problem solved! I think a new one runs around $45.
Ya can't have too many fast Chevys!
Old Jul 28, 2001 | 07:19 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Where is that located? Thanks!
Old Jul 28, 2001 | 09:08 PM
CHVYPWR's Avatar
On the pass. side of the TBI right behind the TPS. Its round and has a 4-pin plug going to it, and it'll take a 1 1/4 inch wrench to get it off.
Old Jul 29, 2001 | 02:22 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Thank you, we'll check on that tomorrow. The rear end is goin' in the RS, too Should be a fun day.
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
Old Aug 3, 2001 | 02:48 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Replaced the IAC... same problem
TPS possibly then? It idles kinda wierd when you first start it, until you start driving for about 5 minutes. I noticed that today.
Thanks!
Old Aug 3, 2001 | 03:07 PM
davehamilton's Avatar
I have a 93 5.7 Silverado . Have you looked at the EGR yet, it wont want to run at low rpm if the egr is stuck open. Also bad plug wires will cause stumble and hesitation--MSD makes a nice set for our trucks-I have them on mine. Good luck
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
