OMG!!! going to carbs!!!
Marck
hellya, that's awesome. quad sidedraft carbs?
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Car: '00 Chevrolet Corvette
Car: C1500
1 carb for each cylinder, it doesn't look like the vacuum would work out right.
Edit: 1 carb for every two cylinders, ok I got it through my head. For all that trouble I'd go tuneport.
[This message has been edited by Keith5 (edited August 03, 2001).]
Uhm, this is an individual runner setup and there is absolutely no vac problems whatsoever.
And tuned port doesn't even compare to this setup wich cranks out 495 ponies, try that with a tuned port
Marck
Marck
Dude that is sweet! It almost looks like a TPI baseplate with the small carbs bolted on IMO. How much does one of those things run $$ wise? Quite a bit i imagine, but if i had it i'd probably get it.
88 Camaro (not an RS, or an IROC, justa camaro.)
305TBI/700R4/2.73
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
305TBI/700R4/2.73
The manifold is a moon crossram and it goes for $1000, the completer setup w/ webers is available from inglese for 4500 bucks but this one is different, I have dellorto's instead of webers and they're turbo carbs, wich can be seen because they have a second set of fuel lines and choke vents on the fuel chamber lid
Total cost would be over 5000 bucks for this baby
Marck
Marck
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
call electromotive, they love turnin those things into fuel injected throttle boddies. with a digital distributorless ignition.
sounds like you have more $ than you need. so that should work out nice since electromotive is far from cheap.
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
sounds like you have more $ than you need. so that should work out nice since electromotive is far from cheap.</font>
Might be nice for when I have the twin turbo's for it!
Marck
[This message has been edited by FAQman (edited August 03, 2001).]
Soulbounder,
This is Twinnie
Marck
This is Twinnie
Marck
I bet thats a real BITCH to tune. I would not want anything looking like that!
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
No, tuning is relativly easy with a unisyn (sort of flow meter)
And if you don't like it, well that's your choice
I like it a lot and that's what counts!
Marck
[This message has been edited by FAQman (edited August 04, 2001).]
I like it a lot and that's what counts!Marck
<font face="Verdana, Arial" size="2">Originally posted by simon:
Looks good, I wonder what it would sound like? Also, what type of air filters bolt up to that?</font>
Marck
simon,
Will do but it might take a while since I just picked up a zf 6 speed and I don't know of anyone ever installing it in a c3 so it might be a struggle but I'll get it up and running
Well.. the K&N's aren't going to work anymore, I now need to 3" inlet Conical filters for this:
Marck
Marck
When you get it all hooked up and running, be sure to post a sound bite for us all to hear! Good luck with your project.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
