tbi spacer
Old Apr 1, 2007 | 08:41 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
tbi spacer
anyone have one? are they worth the $, they seem to be like $125. 1" spacer work with a 14x3 open element under stock hood?
Old Apr 4, 2007 | 05:38 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: tbi spacer
Save your money. A spacer increases plenum volume which is a good way to add power. However, on a stock motor your money is best spent on other items that will yeild greater power gains (exhaust, intake tuning etc). In addition, you will have problems running a spacer taller than 1/2" as the stock linkage and TV cable (for auto cars) will not hook up correctly (not enough slack) and will cause idle and shifting problems.
Old Apr 4, 2007 | 07:24 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
Re: tbi spacer
use the sssseeeaaaaaarrrrchhhh
Old Apr 11, 2007 | 03:45 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: tbi spacer
i've got a half inch spacer that i got off ebay for about $25 from t&t performance products or something, it seemed to increase low end torque, and didn't really effect anything else.
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
