Bogs down on take off
Old Aug 15, 2001 | 09:33 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well we are getting around to the tuning of the TBI I am having one problem I am scanning the real time computer functions with turbo link and the car never runs lean at any time.......Now I am having trouble with the take off the car wants to bog down and then begin to take off (there is no backfire) am I getting too much fuel or could it be something else. I have the fuel pressure just about as high as the factory regulator will let me open it up.
Brian Felts
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Aug 16, 2001 | 05:33 AM
89RS355's Avatar
TTT, I am having the same problem with mine.
Jerry
1989 Lt. Blue RS 5-speed
355 crate motor, Compucam 2040,
PST Front suspension,
Hotchkis rear suspension,
EDL T.E.S., 3" Flowmaster
Harwood cowl hood
1994 Black Z28 6-speed
Nothing major, but FUN!
Old Aug 16, 2001 | 01:05 PM
Tas's Avatar
Tas
sounds like flooding to me.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 16, 2001 | 01:24 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
get the vacuum reg, 17113186. couldnt hurt.
Old Aug 16, 2001 | 02:13 PM
Hey snflupigus do you think the regulator will help and where do I get one?
1989 Camaro RS
Old Aug 16, 2001 | 05:43 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I am having the same problem as well. Weird huh? It bogs only sometimes and it has even backfired up thru the intake, which is odd. But I am going to check my fuel pressure tonight and adjust it. If that don't work. I am gonna try what Nic said.
Old Aug 16, 2001 | 06:31 PM
Well if you are getting a backfire you have a diffrent problem. I am having a fuel problem if you are getting backfire you have a timing problem. I do know that a LEAN condition could cause backfire. Pull a plug and clean it, run it a little and then recheck the plug and see what it says.
Brian
1989 Camaro RS
Old Aug 17, 2001 | 05:24 AM
89RS355's Avatar
TTT
Old Aug 17, 2001 | 06:12 AM
Kyle F's Avatar
Here is another thought. We always have a lot of vacume when reading in real time. So my thought is maybe its not a fuel problem. I think your Throttlebody is too small to flow at the rate that your engine needs. So you have the fuel and timing right, but you cant flow enough air, therefore you are always rich. I think if you back a little fuel out you would be happier with it, but also remember you need new plugs because I am sure they look just as bad as your O2 sensor did.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Aug 17, 2001 | 01:06 PM
snflupigus's Avatar
our tbi is ok, but once you start asking for more fuel, and go over the ~210hp mark, its gona start restricting.
Old Aug 17, 2001 | 05:08 PM
Kyle F's Avatar
We are way past the 210hp mark
Past Thirdgen:
Old Aug 17, 2001 | 09:47 PM
JPrevost's Avatar
Car: 91 Red Sled
The larger the TB unit the more air is sitting "ontop" of the engine. When you open the blades up quick at WOT then you need a really good custom eprom pump shot to make up the difference for the fuel that falls out of suspension. I've been doing a lot of reading and from my experience with carbs, TBI, TPI and all that jazz....TB size is NOT a big problem usually. With a carb you need to get the cfm close, with EFI it means almost nothing. With the carb setups I've been around, the smaller the cfm rating the better the throttle response probably because of the velocity of the air through the carb but.....I really don't see the stock TB unit being a huge problem. I'm having the same problems as you Bryan. Right now I set my "highway eprom" and it's running a lot smoother and closer the 450mv BUT the throttle responce when the car is warm is bad. Big hesitation if I've been driving for some time. If the car is 5 minutes running my throttle response is perfect. Is this the same problem you're having?
Kyle, when is that TTA going to be on the road? Get your butt moving, I want a ride when I get back to Ohio this fall.
, Jon (350 TBI!)
91 Red My website
Old Aug 19, 2001 | 10:38 AM
CamaroRS1990Guy's Avatar
Car: 1990 Camaro RS
Engine: 305 soon to be 383
Has anyone ever thought about adjusting your idle adjuster see mine did that and i knock the idle adjuster pin out and used a tork rench to adjust the highier idle and now it does not bog down only when i is cold but let it run for a minute before you start driveing when it gets warmed up it won't bog down
Old Aug 19, 2001 | 02:03 PM
JPrevost's Avatar
Car: 91 Red Sled
The bog down isn't happening when we put it into drive from park. It's when we are cruising and just floor it into WOT. There is a bog down or hesitation that gets really annoying and hard to tune.
, Jon (350 TBI!)
91 Red My website
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
