how will a cam like this work?
Old Aug 20, 2001 | 12:52 AM
iroc22's Avatar
the cam is a Comp cams and i can't remember the grind number but the specs are:
206/210 duration at .050
.450/.480 lift at .050
1000-5000rpm range
the description for the cam says "for stock TPI engines". Will this cam work with a basically stock TBI engine (mods:headers, exhaust system, intake) the heads will be original but I will replace the valve springs. Also will umbrella valve seals work with the stock heads instead of the GM o-ring?
Old Aug 20, 2001 | 10:13 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
This cam is similar to the GM '350 TPI' cam. I have a similar cam in my LB9 TPI (also a map driven 305) and it is pretty quick with great street manners.
It will work well in a TBI motor but may not be worth the time and effort (read $$$) to buy and install if you are not including it with other mods, eg: headers, free-flow exhaust, intake, etc. Although your factory TBI profile is roughly 176/192 degrees duration @.050 and the new cam represents a 30 degree increase on intake (the only number that really matters), the TBI system is so low-performance from the factory that the cam will need help to REALLY work for you. Have you looked into 1.6 rockers as well ?
have a nice day, RP.
Old Aug 20, 2001 | 11:35 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
TBI doesn't exactly repond well to just a cam change. You'll need hearders and an intake. to make it worth your while. Check the lobe separation on that cam, if it's more than 112* I wouldn't bother with it. my cam is 114* and it's the biggest mistake I've ever made. It'a a pain in the but to tune, it won't hold a constant vacuum so the MAP sensor is going nuts.
With that cam you will get a good low end pull but up high it won't give you much more than you have now. But you could pick come of that up with headers and an intake.
-lars
Old Aug 20, 2001 | 11:51 AM
Brent's Avatar
<font face="Verdana, Arial" size="2">Originally posted by lars92RS:
</font>
I don't understand. Generally the larger the LSA the greater the vacuum at idle. 114 should be easier to tune than say 110-108 given similar duration.
Old Aug 20, 2001 | 12:48 PM
iroc22's Avatar
no no I will be getting a new intake, headers and cat-back with the cam. The cam has a 112* LSA. Do you guys know anything about the valve seals?
Old Aug 20, 2001 | 06:18 PM
DM91RS's Avatar
Car: 91 RS
[QUOTE]Originally posted by iroc22:
[B]the cam is a Comp cams and i can't remember the grind number but the specs are:
1000-5000rpm range
Sounds like a decent cam for a 305. What price is it going for and what intake and headers are you going to use?
91 RS L31 350..... Vortec heads..... Holley 670..... Edel. intake .... Lt4 cam 1.6 rollers ..... Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Old Aug 21, 2001 | 03:52 PM
iroc22's Avatar
I work at an auto parts store in Canada and i can get a discount on all this stuff. The price is $300 canadian, which is insanely cheap. The intake I'm goin for is edelbrock. headers I think will be dynomax cause i can get them for 500 painted. Cat-back will be dynomax also. You guys know anything bout the dynomax dual exhaust kits for our cars? I have no idea if they exit after or before the axle
Old Aug 22, 2001 | 11:26 PM
Basett_Racing's Avatar
I don't know how much $300 would be in American dollars, but you can buy a new LT1 camshaft from Advance auto parts for $76.99 + tax. It has 205* dur int, 207* exh, and has .447" lift int, .459" lift exh. It is a little smaller than the Comp one, but it is proven to work well with TBI.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
