Bouncing tach at Idle...
Old Aug 22, 2001 | 12:59 PM
92fire-audio's Avatar
I just noticed this this morning, if the car isn't heated up, the tach bounces between 800 and 1000 rpm, like it's having trouble idleing.. Any ideas on what this could be?
I'm gonna go for a spin and see if heating it up a little helps it out...
Old Aug 22, 2001 | 02:09 PM
92Camaro305TBI's Avatar
not sure, but when I start mine up and any time(hot or cold) It will idle at 850 and then drop to 500 after 2 sec. It started after I change my exhaust. But im not too sure.. Anyone have any ideas?
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
Old Aug 22, 2001 | 05:04 PM
NJ SPEEDER's Avatar
if your IAC motor is worn a bit and starting to go or if the O2 sensor is toasted, it can cause mis reads in the ecm that will make this happens.
get a can of gumout tb cleaner spray and use it liberally on the tb, throught eh blades and down the IAC port, while revving to engine. if it is the IAC being clogged this will likely solve the problem.
the way to tell if it is the O2 sensor is to get out on the highway and drive for a bit, if it is getting bad reads the ECM will pitch a code after you have driven a few miles at constant speed or as soon as you lift after going a constant speed. teh car will also feel a little "loaded up" like it is getting to much gas sometimes if the O2 sensor is bad or going.
hope this helps
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Aug 22, 2001 | 10:02 PM
I replaced the O2 sensor about 3 months ago, I doubt that is it.. I'll try spraying the TB off first.. Thanks
Old Aug 25, 2001 | 04:31 PM
JPrevost's Avatar
Car: 91 Red Sled
Does the car windmill when you start up cold? How about when it's warm? The flex in idle can also be a misfire from bad spark plugs. Pull off the distrib cap and make sure everything is clean (white powder is normal). Also check most of your spark plugs, what kind of plugs are you using? What is your base timing set at? Lots of questions will help us figure out your problem. Is this when you're in gear or park? Does the car almost stall out when you put it into gear? WE NEED MORE DETAILS. It could also be your alternator but I think you would have noticed any bouncing around of the voltage needle (13-14 back and forth) but that is usually not dependant on cold start.
Definatly clean out the IAC with the cleaner. The IAC will actually go to 160 while in park and then back itself down till your max warm (or cold) idle rpm speed is (eprom dependant).
, Jon (350 TBI!)
91 Red My website
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
