Where does the vacuum line behind the pass side fuel line go to?
Old Sep 1, 2001 | 04:55 PM
92fire-audio's Avatar
Right now I have it connected behind the distributor on the little T connector, i'm not sure if this is right.. Anyone know where this one goes???
Old Sep 1, 2001 | 06:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Without looking, I'd say to the vacuum reservoir ball.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Sep 1, 2001 | 07:58 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you mean the one that comes out the back of the tbi? here you go.
looking at front of tbi.
left on tbi goes back around to the little electrical thing that has 2 vacuum lines on it(egr controller). it goes on the far left one. the inside one, goes to the metal disk(egr valve)
rear goes to far left near the firewall( on my car there is a green clip on the electrical plug next to where the vacuum hose hooks up.(map sensor) dont know if thats standard color.
big one = pcv valve on drivers side valve cover.
one below big one in middle goes to cruise.
right = plugged with vacuum cap.
Old Sep 2, 2001 | 09:10 AM
Still lost, I meant the one that is next to the EGR, right behind the fuel line but not on the TB. It has a nipple that bolts into the manifold.. I'm just not sure where its supposed to go...
Old Sep 2, 2001 | 11:22 AM
Ok, I think I found the problem..
Where does the vacuum line that is right between the 2 fuel lines on the throttle body go to?
I don't have that connected and I think thats the problem...
Old Sep 2, 2001 | 05:33 PM
snflupigus's Avatar
the one coming out the back of the tbi between the fuel lines goes to your map sensor.
Old Sep 2, 2001 | 11:54 PM
Ok that got it.. Now the car runs fine except it shifts at 2000 rpms and it won't automatically downshift even when I stomp on it..
I think i need to adjust the TV cable...
Old Sep 3, 2001 | 12:25 PM
snflupigus's Avatar
thats an affirmative on adjusting the tv cable.
Old Sep 3, 2001 | 05:48 PM
Thanks to everyone who helped.. I got the car running in top shape now.
I would actually recommend the Edelbrock TBI manifold now.. Except I had to have the bracket that comes off the compressor(or whatever that is) Drilled and tapped. Edelbrock says that it was made for trucks so they stopped drilling that hole.. whatever..
Thanks once again!
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
