oil pressure....
Old Sep 14, 2001 | 04:00 PM
pimpintheRS's Avatar
oil pressure....
okay i was wondering where most of your guys oil pressure sits at.. my oil pressure sits at 30.. should i get a new oil pump or what? how much do they cost and how hard are they to put in? i dont know if that is what caused my car to drop in oil pressure but the only thing i would think it would be is the oil pump going dead...
Shawn
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like
removed rear hood seal.. runs much cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
Old Sep 14, 2001 | 06:54 PM
NJ SPEEDER's Avatar
sits at 30psi at what rpm? if it stayts there all the time it is more likely that the gauge is actually dead, not the pump. if the pressure sending unit was bad it would be pinned past 60psi so we know that isn't the prob.
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 14, 2001 | 09:21 PM
nope sometimes it drops lower... should i just change the oil pump i was also wondering if a cracked head could cause this?? just what i need that is a pita...
Shawn
Old Sep 15, 2001 | 12:33 AM
Greg Kuhlmann's Avatar
mines weird... sometimes it goes to 30, but i just changed my oil and for some reason it seems to be higher which is good... if i let it idle for a few minutes it still goes low... but it has never really scared me. i used to think it was the pump... but i just changed the oil and it has made it go up average of about 15 psi.. i dont know why it would.. but it seems like it did for me
Old Sep 15, 2001 | 02:57 AM
i just changed my oil and it is chillin around 30 psi... it used to just kick it at max before it kind of worries me i am wondering if this is because of the heat or what... i am using 20x50 oil is that bad? i live in hot a$$ weather too..help me i dont want to worry about my baby.. hahahahah
Shawn
Old Sep 15, 2001 | 03:10 AM
rezinn's Avatar
Okay guys, think about it.. oil pressure will not be the same in all circumstances. When its cold, its going to be higher. Higher rpms=higher oil pressure. So when you start your car, the pressure will be high..as it warms up the pressure will drop, then when you drive around it will get higher as your engine moves faster.
Old Sep 15, 2001 | 11:27 AM
okay i knew all of that... i was wondering if it being this low is normal it never got this low last summer...what oil pressure does your car drive around at?
Old Sep 15, 2001 | 11:33 AM
OldBlue's Avatar
just idlin its just below or right at 30 then cruising it goes 45 or so then when I really start rompin on it sometimes it goes all the way up to the line after 30 wich is prolly right around 47-49 , but usually stock guages are off. Thats where its on mine though
Old Sep 15, 2001 | 03:30 PM
JPrevost's Avatar
Car: 91 Red Sled
If the needle is dancing with the engine and isn't in either of the red zones you're A-okay. If you change your oil and the pressure goes up, then you know it was about time to change your oil .
, Jon (350 TBI!)
91 Red My website
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
At start-up, mine sits around 50 at idle, then drops and rises as I drive depending upon acceleration, etc. After it warms up it's about at 45.
Old Sep 16, 2001 | 01:29 PM
okay it hangs out around 30 psi and after warm up it drops a lil below ... after all the post i think it might be a dead needle giving me an inacurate reading...
Shawn
Old Sep 16, 2001 | 02:43 PM
Silverado5.7L's Avatar
Hello
That bothered me for a while too.
I have a 91 5.7L Auto in a Truck
Mine sits at about 35 when cold.
27 when idleing warm, and 33 when driving warm.
My rpms don't really get over 3000 though.
Should a truck have more then a car?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
