91 305
Old Sep 14, 2001 | 10:01 PM
91camaro305RS's Avatar
91 305
ok i think ive decided on the preformer elderbrock setup....with a lt1 cam....and stuff....as far as the cam does with i need to do any rocker work? srpings...new?
and what lt1 cam will i need....lift and stuff? i was planning on goin with a double roller timing chain...is that over board for my engine...alos with my tbi elderbrock intake....will and headers...will i need a fuel system upgrade...explain.....and i know i'll need a chip
thanks
nathan
Old Sep 16, 2001 | 01:49 AM
ZRATED's Avatar
The best lt1 cam was made in the newer years
96,97 and with that cam swap you wiil also ned a set of new springs. Just a little info for you.
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Tx Smog Pump Delete option
Valve cover breather
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
96 LT1 cam with
New liffters and timing chain
All the free TBI mods
Old Sep 16, 2001 | 09:37 PM
BahamutRS's Avatar
You don't NEED new springs...you SHOULD get them though. I didn't.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
MSD 8.5mm plug wires
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 19, 2001 | 05:49 PM
DM91RS's Avatar
Car: 91 RS
How much does the LT series of cams help an LO3 without changing the heads? I have a good breather setup and headers with a 3" exhaust system. I have an LT4 cam that I can install and was wondering if it made any differance without changing or porting the stock heads?
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
