Restrictor Plate Cam Lobe Profiles. Good for us?
Old Sep 23, 2001 | 07:28 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Reading hotrod. they are building a nice 289 ford. reading, they are using a custom comp cams ground shaft, using winston cup style lobe profiles to help compensate for the two barrel carb they are using on this vintage racing engine that requires a 2bbl. "the design reduces seat time to bleed cylinder pressure at low engine speed but bolsters intake flow as revs climb to offset a restrictive intake tract."
the above sounds like it could be good for us too.
specs: duration @ .050: 244/248
gross lift: .584
lash: .018/.020
centerline: 109
1.6 roller rockers.
the engine is 9.25:1 compression with heads that flow 237 intake and 185 exhaust. they also intentionally limited the exhaust port flow to less than 80 percent of intake flow above .400 lift to maintain a scavanging effect.
these mods to this 289, built for a mexican road race, have some principals i think we could apply to modding our engines as well. what do you guys think.
btw this 289 ford made 350hp @ 6700rpm & 316ft/lbs, with a 2bbl, on 87 octane.
Dale Earnhardt, #3 has crossed the finish line with a victory.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Sep 23, 2001 | 09:09 PM
Tas's Avatar
Tas
how does that cam duration compare to stock? can the TBI computer handle it?
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 23, 2001 | 09:21 PM
NJ SPEEDER's Avatar
that would read as way to much lift with way too much duration. it would have no vacuum at idle and it would make the ecm completely flip out.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 24, 2001 | 11:00 AM
fast_broker's Avatar
NJ is right. Those fancy words mean TONS of overall and .050" duration... with 109 lobe center, it would be a miracle if the engine even started/ran with an OEM'ish PROM. VERY low vac signal on that baby at idle, and it would have to idle at about 1300-1500rpm to even start a vac signal...
Old Sep 25, 2001 | 11:59 AM
snflupigus's Avatar
you guys all missed my point.
i wouldnt dream of putting a cam like that in a stock l03.
im wondering if with some nice heads, lighter bottom end, new chip etc...
do you think that with a 2bbl tbi (the small one even), you could push 350hp with a 305?
i know it wouldnt idle well, stockish chip or not.
Old Sep 26, 2001 | 11:30 PM
snflupigus's Avatar
i see how you are, dont want to get into this conversation? o well.
midge54
Dec 27, 2019 04:14 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
camaro71633
Sep 1, 2015 10:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
