timing and stock 305 TBI on 88 camaro
Old Sep 25, 2001 | 09:03 PM
88camaro305TBI's Avatar
Ok, just replaced EGR solenoid and the engine is knocking now... how do you adjust the timing on it, the nice sticker on the hood has been painted over by previous owner....its an 88 camaro, 305 TBI, no mods (yet)....help!
PS. I really just need to know what that darn sticker says...if you have that info i'd GREATLY appriciate it! Thanks!!
[This message has been edited by 88camaro305TBI (edited September 25, 2001).]
Old Sep 25, 2001 | 09:16 PM
89 4Mula 350 Tbi's Avatar
I think its 0 degrees befor tdc and you have to disconent a wire by the blower motor its brown i think also the car has to be in drive.
Old Sep 25, 2001 | 09:18 PM
heh ok...its a 5spd btw....thanks!
Old Sep 26, 2001 | 09:00 AM
Ok...is there a marking on a flywheel so I know when it is @ btdc? and I just turn the dist to 0 degrees? how do I tell when its at 0 degrees? sorry about the possible stupid questions...I have a Haynes manual and it just says to follow the VECI label (which has been painted over)...thanks for the help!
Old Sep 26, 2001 | 11:27 AM
NTChrist's Avatar
Yeah, make sure to disconnect the EST (electronic spark timing, or something), which is the tan on brown wire that 89 Formula mentioned. After doing that, you check the timing using a timing light. If you need more instruction on that, I'd suggest buying a book. The little notch on the, ummmm, spinny thing attached to the crank (damn vocabulary has left me, maybe I need to buy a book) is the indication of where the spark is occuring. Line that up with the timing tab 0* mark, above the timing cover, by rotating the distributor.
Edit: Just to simplify, you can tell when the engine is at TDC on the #1 cyl by the aforementioned mark lining up with 0*.
No guts, no glory.
[This message has been edited by NTChrist (edited September 26, 2001).]
Old Sep 26, 2001 | 11:52 AM
gotcha....mart the notch on the pully to the notch w/ the deree measurements...and adjust it by rotating the distributer
Old Sep 26, 2001 | 02:03 PM
IROCZ89's Avatar
NT,
The round thing is the harmonic balancer.
Phil
89 IROC 5.0 TBI
89 RS 5.0 TBI, T-Tops, Soon to be a IROC clone.
Old Sep 27, 2001 | 12:25 AM
pianiy's Avatar
If I'm not mistaken I believe our TBI's can be advanced as much as 6* before theres any detonation. I could be wrong... experimentation is the only way to find out.
~Luke
'91 Firebird :: L03/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
::R.I.P.::'87 Firebird - Firebird parts - Selling an '80 Firebird for a friend
Moderator of tranny board over at TransAmGTA.com
Old Sep 27, 2001 | 06:12 AM
Well it sounds more like the knocking could possibly be coming from the crankshaft...possibly a connecting rod....it sounds loke your rapping on it with a wrench...tap tap tap... and only above 1500 RMP...oh well...fun fun...well that will be a nice project.
[This message has been edited by 88camaro305TBI (edited September 27, 2001).]
Old Sep 27, 2001 | 08:59 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by IROCZ89:
NT,
Phil
</font>
Just an FYI, no flames intended.
Harmonic vibration damper (or harmonic damper) is the correct term. Some also act as an external balancer, such as the 400 SBC, but they are really a damper.
AJ
Old Sep 28, 2001 | 09:39 AM
IROCZ89's Avatar
AJ,
No flame taken. Just always called it a balancer. I think the names are recognized either way.
Thanks,
Phil
Jae992
Aug 27, 2015 09:07 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
MENINBLK
Aug 5, 2015 11:58 PM
