Running Rich
Old Sep 25, 2001 | 07:25 PM
DJdude's Avatar
Running Rich
Hey i have a 92rs just replaced the motor still 305TBI,K&N,Helix power tower(tbi spacer),flowmasters,no cat(piped over),street&performance elec. chip,open element air cleaner,removed hood seals.
my question is what could be making my car run rich i can smell it in the exaust and how can i fix it, also my SES light comes on but i don't have a code reader thing. can ya help me out
92rs
new 305TBI cratemotor
K&N
flowmasters
no cat(piped over)
removed hood seals.
"I live life a quarter mile at a time eatin fords and ****tin ricers"
Old Sep 25, 2001 | 10:57 PM
NJ SPEEDER's Avatar
you may want to look at the O2 sensor. that is the most common cause of the car running dead rich and throwing a code. if it fails or misreads it will just go to a default of reading "LEAN" and the ecm will add all the fuel it can get it's hands on. a new one is only about $20, so you may just want to swap it and see.
if that doesn't work, i woudl talk to the people you got the chip from if it is a custrom unit, they may have made a mistake in a perameter somewhere.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 26, 2001 | 03:56 PM
DM91RS's Avatar
Car: 91 RS
To read the codes you do not need a scanner, you only need a paper clip bent into a u shape and instal into the a and b terminals of the diagonstic link connection under the dash. Have the ing. key off, insert the paper clip and turn the key to on, but don't crank the car. The service eng. light will flash a sequence of numbers that you can look up in a manual or find online. This might be in tech central on this site. I did not look. Good luck.
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Old Sep 29, 2001 | 08:22 AM
DJdude's Avatar
ok i used that wire trick and threw 12,23,32,12 i heard the twelves are just at begining and end all the time that theres no problem there and i think my tbi spacer is whats givin me the 23 because i never adjusted my throttle line but i have no clue where the 32 came from
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
