Can anyone decode this?
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Ok so i'm a bit puzzled at this. 10110810 is the casting number for the heads off my 350 TBI truck engine 14093638. from one source they are 350 heads 65 cc chambers, from a 91 or newer. from another source they are 84-91 305 heads with 184/150 valves. first source was mortec, second is a smallblock ID guide. so my question is, does anyone have any true data? i only want to know because i don't have access to any way to measure the things, and if they are worth keeping for use on that same engine to go into my S-10.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Can anyone decode this?
Finally the engine may have a stock roller cam depending on when it was produced. 92+ should be roller cam equipped.
Car: 89 RS
Engine: 305 carbed
Ok now i know what dimension the heads are. I already know the block is a 88 roller block because of the bolt holes in the valley for the spider. Are those heads worth rebuilding? i don't have alot of money to spend so new heads are kinda out of range. when i rebuild this engine i'll get OE roller parts and stuff a comp cam in it. i don't intend it to be performance just mainly towing so torque is important.
Elephantismo
Feb 13, 2019 12:51 AM
