Open Air Filter IAT?
Old Apr 24, 2007 | 11:22 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Ok i know this is going to sound like a stupid question but how do you remove the IAT sensor from the original air cleaner system to put in an open air cleaner. I dont want to tear it out or anything since ill probley have to put the old one back on when i have to get it smoged. Also since im on the topic of air filters and smog will an open air filter effect my smog i live in California and i know there known for having hard smog laws. I searched and downloaded that instruction guide but it just says remove IAT from old air cleaner but idk how and i dont want to break it just in case it is an expensive part.
Old Apr 25, 2007 | 12:58 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Open Air Filter IAT?
ok to remove the iat from the old cleaner--when you look on the inside of the cleaner at the sensor there should be a metal ring around it, just take that off and pull the sensor down. new they are 20 at advance auto parts, or free at the junkyard if you are sneaky
and an open element should not affect smog. hope this helps you, i can take a pic of what i am talking about with the sensor if you need it, let me know.
Old Apr 25, 2007 | 01:03 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Thanks for the response im gonna give it a shot tomorrow afternoon.
Old Apr 25, 2007 | 01:09 AM
cool let me know if you need more help
Old Apr 25, 2007 | 01:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Won't affect smog BUT you need the original air cleaner in order to pass the visual part of the smog check. It has to do with the thermac system, you know all those fancy valves, lines and the heat riser tube (from the exhaust manifold) on the original air cleaners.
Old Apr 25, 2007 | 02:00 AM
[IMG][/IMG]
here is a pic for you. the metal piece is the ring i was talking about. the little prong thing on the front, you have to bend that out and the sensor should pull right out.
Old Apr 25, 2007 | 02:16 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Thanks for the picture one more question. Is an open element filter worth the trouble. Like is it a gain i will notice or is it just better for the engine. My car right now is all stock though over the summer i plan on installing a new exaust system. Just wondering if its worth having to take off when i have to smog it.
Old Apr 25, 2007 | 03:35 AM
the 14x3 will flow more air, might not be a big gain now, but once you start improving the motor it will help out
Old Apr 25, 2007 | 08:35 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Hey i wanted to thank 91 camaro racer for the help. I got it installed but ended up taking it back cause my idle got rought when it was on and it was right on top of my coils. I did put something between it though while testing it out so nothing bad happened. Once i put my old filter back on my idle was normal again. Is this something common or anything?
Old Apr 25, 2007 | 11:25 PM
first off i just want to say thank you to dekoy411--it is no problem, thats whey this forum is here so we can all help each other. i love working on my car and i love helping people so they can get better at working on theres!!
it could be taking the voltage out of the wire so less went to the plug, most people just put a little bit of cardboard or something so they don't rub each other.
also how long did you run it when it was rough? it could be that the computer might just need to "learn" a little since it has more air? just an idea.
Old Apr 26, 2007 | 01:06 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
I drove around with it for about an hour or so on and off. It only was rough when i was stopped and it was in drive. When in neutral it didn't idle rough which i thought was odd.
Old Apr 26, 2007 | 01:08 AM
what are your rpms at when it is in drive? if your tach works
Old Apr 26, 2007 | 01:37 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
At 500 or a little above 500. My rpm stayed the same with my stock air filter though it didn't idle rough at all. I thought maybe it was idling low but the number was the same so idk.
Old Apr 26, 2007 | 01:58 AM
well i am not sure what to tell you then. sorry
Old Apr 28, 2007 | 06:41 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
I just noticed something from reading other topics about it and i realized that i forgot to plug that vacuum line i'm wondering if that would make the difference. Plus does the elite series air filter fit in with out touching the coils and does it still screw in with out a problem that seemed to be the problem i had with the other filter i had too.
Old Apr 29, 2007 | 12:33 AM
yeah leaving a vacum connection unpluged will really throw off your idle, not sure about the air filter
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
