I need some recommendations please...
Don't think I spelt it right, anyway
I have everything modded in my sig... What I need now is to get to my 300Hp mark...
The next thing That I want to do is Intake manifold and Cam.
I was looking at the lt1 cam but seems like I would need something a lil more aggressive...
Any IDEAS PLEASE
Also I will be needing a chip and gears. I am going with 3.73 gears...
PLease do not flame me.. I just want parts and ideas..
DO NOT TELL ME TO DO A 350 SWAP>> IM NOT GOING TO.
Thanks for your help....
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit(Rebuilt Tranny)
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Edelbrock TES 1 3/4" Headers
Future mods?
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
Any IDEAS PLEASE
Future mods?
Rockford 800x2 Amp
Custom box
4gauge wire kit
manifold,cam,and then go to THE BOTTLE!!thats what im going to do.
just my 2 cents.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims,Z28 bowtie grille insert with driving lights
-L03 305,TH700R4,2.73's,only mods for now are...Flowmaster 80 series replacement muffler,accel wires and coil,14x3 open element with K&N,lockup switch at the track,and a catco cat.
-best 1/4 mile times to date:15.89@86 with a 2.26 60 ft
just my 2 cents.
You'll never get 300hp with stock heads, so you're gonna need heads/cam/intake, good headers, ec. Don't ask me what is best. I am a 350 man... Lift of cams I would recommend will hit your cylinder walls (LT4 Hot Cam) unless you bore your cylinders...
Good luck, 300hp 305 naturally aspirated is abit of work and money.
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
My engine is at around 250 hp(200 rwhp) with the mods that I have. You will definitely have to scrap them cylinder heads if you want them numbers. Contrary to everyone's beliefs, Trick Flow's Twisted Wedge 350 heads with 2.02 intake valves will fit a 305 bore if you feel like spending money on good cylinder heads.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Best 60' - 1.9 secs
Check it out
